Usage of Total Mesh Displacement in CEL for Movement Computation |
August 30, 2016, 08:32 |
Rep Power: 13 |
I'm trying to solve a bending case, causing problems with mesh stiffness. . For visualization: 2 is bending and the subdomains 1 should move downwards according to the Total mesh displacement. In 2D the application of: Code:
maxVal( Total Mesh Displacement Y )@REGION:FSI_y_2 Coming to my question: If I'm trying this in 3D, there are curved shapes leading to unsuitable shifting values for the subdomains. Is there a possible way for copying the movement of a 3D area to another? Thanks in advance |
August 30, 2016, 20:54 |
Rep Power: 144 |
You could use the probe function to get the displacement at one point and use it to define the motion of another boundary or subdomain.
In 3D for complex shapes I would consider using the default mesh displacement diffusion method. |
August 31, 2016, 01:41 |
Rep Power: 13 |
thanks for your input. I am actually using the displacement diffusion method (but with a value function). The problem is the stiffness. Due to the small gaps and close walls (my bending geometry as well as the enclosing one) none of the built-in settings works properly. Thats why I'm stuck with this workaround. The outer region 1 needs to be moved downwards so the inner one can be deformed with a suitable stiffness. I enclosed part of my example studies with deformations. |
September 2, 2016, 03:39 |
Rep Power: 13 |
sorry for double posting ... I start again with a motion undefined region close to my moving element and with an enclosing domain, that I'll force to move. As the second picture clearly shows: one problem is the continuity of movement. Is it somehow possible to take the Mesh Displacement Y of an edge (with a named selection for addressing) and create a CEL / UDF function (close to the probe thing ghorrocks mentioned) and create a function dependant on a coordinate (lets say x) for application as a movement input? Someone did something like this? |
September 2, 2016, 07:13 |
Rep Power: 144 |
If you can't get the mesh deformation stuff working you can do dynamic remeshing. The tip of your device covers quite a large size range and dynamic remeshing would help here.
Having said that I think with some careful planning you should be able to get this working with mesh deformation only. Have you considered a GGI at the end of the paddle so the mesh at the end hardly moves, but the paddle can slide up and down with a GGI? |
September 2, 2016, 07:37 |
#6 | |
Rep Power: 13 |
Currently I don't use interfaces ... I thought about the sliding of meshes but didn't manage to get it working correctly so far |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
