setup stage in CFX - outputs
Old   August 26, 2016, 14:46
Default setup stage in CFX - outputs
cyln
cyln is on a distinguished road
I will start running a series of simulations in CFX. The first one will be based on the solution of unsteady Navier-Stokes eqns without a turbulence model. Other simulations will include a turbulence model. I generated the mesh on ICEM and it seems ready.
The results I am trying to get:
-turbulent kinetic energy
-time-averaged velocity magnitude
-time-averaged vorticity magnitude
-momentum thickness Reynolds number
-variation of frequency spectra
-instantaneous vorticity magnitude
-instantaneous perturbation vorticity magnitude
-time-averaged turbulent kinetic energy
I did run a simulation just for testing (without a turbulence model). However, I could not find the options in CFD-Post to obtain some of the results above.
Do I have to specify my expected results in setup stage? or do I miss sth else? How can I tell CFX to give me the above results?
Thanks.
cyln is offline   Reply With Quote
Old   August 27, 2016, 07:39
All the turbulence related parameters are not modelled as a turbulence model when you select the laminar flow model. You then have to develop expressions to extract the turbulence from the flow field fluctuations (if any exist). How to so this is a whole new question...
Flow parameters like vorticity in in CFD-Post for laminar or turbulent models, under the puzzlingly labelled "..." button.
Old   August 27, 2016, 08:42
cyln
Thanks ghorrocks for your reply.
Then can someone recommend any paper/manual to develop and implement such expressions on CFX? Im not so experienced with CFX, but I think I can manage that..
Old   August 27, 2016, 08:53
Have a look in a good turbulence modelling textbook like "Turbulence Modelling for CFD" by Wilcox. Also my PhD thesis has a short discussion on a few options: https://opus.lib.uts.edu.au/handle/2100/248 in chapter 6.
The ANSYS CFX solver exited with return code 1 kola77 CFX 24 April 11, 2022 08:32
The CFX Setup case file no longer exists. Continuing in an initial state. ced30 CFX 1 November 13, 2015 13:00
Script CFX Setup for dynamic domain generation kar.coep CFX 1 May 18, 2015 03:29
CFX Parallel Setup on windows 7 x64 SlicedBread CFX 1 November 14, 2011 18:06
setup K,E parameters in CFX 13 fek66 CFX 8 May 21, 2011 19:01
