vof fluid sloshing dispersed fluid and continuous fluid |
November 2, 2016, 18:03 |
#41 |
Rep Power: 144 |
It is propriety to me (well, my company actually as I did it for them).
But I suspect I will be able to share it. My company is pretty good with the open source idea so it should be fine. The only problem is it has been a long time since I used it so I am a bit rusty with it. Anyway, give me a PM and I will see what I can do. |
November 10, 2016, 00:27 |
#42 |
naveen kumar s
Rep Power: 10 |
hi glenn,
i have another question, in my simulation, i have simulating for different liquid levels, what happened means for small liquid level say 20% tank height is liquid level for this small liquid level i got good answer, later i changed only liquid height for 60% tank height but in solver i getting error as fatal over flow, and result dint created, is that due to mesh , do i need to change mesh, even why this error is coming, thank you glenn.. and i have attached one image of solver snip image, in that i have marked in that what is that F means, |
November 10, 2016, 04:31 |
#43 |
Rep Power: 144 |
This suggests the simulation is numerically unstable. Try: double precision solver, better mesh quality, smaller time steps.
dairy equipment, dispersed fluid, sloshing, sloshingtank3d, spray dryer, vof |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Multiphase flow with two continuous fluids and one dispersed fluid | ashtonJ | CFX | 5 | July 25, 2014 07:31 |
How to choose the mean diameter value for dispersed fluid? | creddy_trddc | CFX | 1 | October 30, 2011 05:30 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
