Yuva
Rep Power: 10 ![]() |
Dear CFD community
I want to simulate the flow inside a Radial turbine but an Inviscid one, How can I change the option in CFX to run an Inviscid flow simulation ? Thank you for your help |
Rep Power: 144 ![]() ![]() ![]() ![]() |
CFX cannot run with zero viscosity. But you can define a fluid with such a low viscosity that it is in effect inviscid. Try reducing the viscosity of air (I assume it is air in your turbine) by a factor of 1000. If it diverges then try reducing by a factor of 100.
Rep Power: 33 ![]() |
In addition to Glenn's suggestion, adding Free Slip Walls will also make it more consistent with an inviscid model
Yuva
Thank you for your answer
What about the Turbulence Model for an Inviscid flow ? and the Turbulence option for an Inlet Boundary Condition ? Kind Regards |
Use a laminar flow model. There is no need to model the turbulence equations when they don't do anything.
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
Wind Tunnel Flow Simulation Mass Flow BC Issue | ledelman | SU2 | 4 | August 3, 2014 18:38 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 06:12 |
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 09:49 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
