Pressure Boundaries for contactless seal with thread (pump) |
August 24, 2016, 10:32 |
Luke Miller
Rep Power: 10 |
again, I have some trouble to define pressure boundaries and calculate the correct pressure in CFD post. I’m trying to simulate a contactless seal with a thread, like a labyrinth seal. The fluid is “pumped” by the rotating thread from side A to B (See picture 1) In my simulation, I let the wall rotate in opposite direction, that’s easier to simulate. First attempts look good, the flow direction is correct (picture 2) On both ends I defined an Opening with “Opening Pressure = 0 Pa” (Normal to Boundary condition). So I have no real Inlet and Outlet conditions.(picture 3) But the pressure result seems not to be correct, compared to analytical calculations from a book. Regardless from my results, how would you define the boundary conditions?
Current Software: ANSYS CFX 16.2 |
August 24, 2016, 21:02 |
Rep Power: 144 |
You define the boundary conditions to describe the conditions at that location which exists in the system. I have no idea what is upstream or downstream or this device so I cannot make a suggestion.
If the pressure field is wrong can you post an image of what you are getting and another image showing what you expect to get? |
August 25, 2016, 10:00 |
Luke Miller
Rep Power: 10 |
Okay, I’ll try to explain in a different way. Imaging a threaded rod or a screw, which rotates in a hollow cylinder. The gap between the thread an inner wall of the cylinder is very small (0,2mm) compared to the diameter of the screw (30mm). When the screw rotates, it can pump from one side to the other. In this case the fluid is oil. The mechanic is used for contactless seals. And I want to simulate the pressure, which this “pump” can produce.
The analytical formula says, that a max. pressure of 147658 Pa can be produced with a mass flow of 0,00898 kg/s My results in CFD Post are: Area Average of Total Pressure on Inlet 806.233 [Pa] Area Average of Total Pressure on Outlet 1460.77 [Pa] Mass Flow on Outlet -0.00698017 [kg s^-1] Like you see, the mass flow is almost the same. But pressure is far away from the other result.
August 25, 2016, 19:59 |
Rep Power: 144 |
What does the analytical formula assume? Are you sure the analytical formula is right?
Then there are issues about basic simulation accuracy, discussed in the FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F In this case mesh resolution would be a key factor I think. |
labyrinth, pressure boundaries, pump boundary condition, seal, thread |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 19:57 |
Operating condition in Fluent | MASOUD | FLUENT | 3 | September 16, 2010 18:50 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
