August 23, 2016, 17:41 |
A problem with CFX setup
Have a nice time!
Rep Power: 11 |
Hello, attached the snapshot of the 2 warning messages ...Could anyone tell me how I can fix the problem? Thanks
August 23, 2016, 18:02 |
Aja
Rep Power: 14 |
I think that you should specify initial value in your simulation(this is just a idea)..Do you consider this case?
August 23, 2016, 18:08 |
Have a nice time!
Rep Power: 11 |
I am going to check it out and tell you sir, thanks..
August 23, 2016, 18:13 |
Have a nice time!
Rep Power: 11 |
You are right sir thanks a lot...but what about the second warning message? Thanks
August 23, 2016, 18:17 |
Have a nice time!
Rep Power: 11 |
Okay I have solved the second too...I have to set the transient results tab...but I have to set monitors to watch the static pressure with flow time...I have set the point but I want the results to be written in a file..Do you know how is this? Thanks
August 23, 2016, 18:25 |
Have a nice time!
Rep Power: 11 |
After the run I got this error..what is the problem?
Thanks |
August 23, 2016, 18:31 |
#7 | |
Aja
Rep Power: 14 |
Areaavrage(pressure)@inlet This is just a idea! But if you study the following document, you can set monitors to watch the static pressure with flow time: Last edited by aja1345; August 25, 2016 at 13:14. |
August 23, 2016, 18:34 |
#8 | |
Have a nice time!
Rep Power: 11 |
August 23, 2016, 18:37 |
#9 |
Aja
Rep Power: 14 |
August 23, 2016, 18:41 |
#10 |
Have a nice time!
Rep Power: 11 |
Thanks, the link works..but what about the error of the snapshot? thanks
August 23, 2016, 18:50 |
#11 | |
Aja
Rep Power: 14 |
1. I think that you are using periodic rotational condition. if so, you check axis of periodic rotational that is right or not. and consider rotational axis of turbine that rotational direction is ok or not. 2. of periodic rotational faces is or not? if it is not , you use method. consider this case. 3. Consider that mesh quality is good or not. These cases are my experience and just a idea! 4. in last, have a look in the following link: http://www.cfd-online.com/Wiki/Ansys...gence_criteria Last edited by aja1345; August 25, 2016 at 13:14. |
August 23, 2016, 18:54 |
#12 |
Have a nice time!
Rep Power: 11 |
Thanks a lot, but how can I check out the axis of periodic rotational, and the mesh of periodic faces? thanks again...the mesh is fine...it has been generated by ICEM, ansys mesh and turbogrid.
August 23, 2016, 19:26 |
#13 |
Aja
Rep Power: 14 |
August 23, 2016, 19:38 |
#14 |
Have a nice time!
Rep Power: 11 |
Thanks, I will try it and tell you sir!
Many thanks...You are so helpful.. |
August 23, 2016, 20:14 |
#15 |
Have a nice time!
Rep Power: 11 |
I have fixed the error but the cfx stop running...Do you think this is because the elements are over 2 million elements and I am running it on my pc?
August 24, 2016, 04:59 |
#16 |
Aja
Rep Power: 14 |
Yes. quality mesh can affect on your simulation.
1. You see the following video in youtube. I think that help to you. This video is about centrifugal pump. https://www.google.com/url?sa=t&rct=...29759880,d.bGs 2. Also study the following paper(PDF Available): https://www.researchgate.net/publica...sing_ANSYS-CFX 3. Search in forum and google and other sites. There are many thread and document is about centrifugal pump. Last edited by aja1345; August 24, 2016 at 07:55. |
August 24, 2016, 10:54 |
#17 |
Have a nice time!
Rep Power: 11 |
Thanks, I am working on it...
August 24, 2016, 11:47 |
#18 |
Have a nice time!
Rep Power: 11 |
I have solved this error by the initialize tab in solution.
August 26, 2016, 16:53 |
#19 |
Have a nice time!
Rep Power: 11 |
Hello, I have got a warning message " CFX license doesn't allow using parameters, the results may be affected by this and the solver may run in an unaccepted behavior"
what is the problem please? thanks |
August 31, 2016, 04:44 |
#20 |
Maxim
Rep Power: 13 |
those last two error messages are self-explaining. I guess that's why no one answers here anymore...
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 19:05 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
cfx mesh problem... | mactech001 | ANSYS Meshing & Geometry | 0 | November 5, 2009 02:19 |
problem in displaying surfaces in CFX | haho | CFX | 1 | July 5, 2009 19:25 |
