August 23, 2016, 07:01 |
fluid structure interaction
naveen kumar s
Rep Power: 10 |
hello
I have doing simulation of sloshing in rectangle tank, and it has simulated, now my question is when fluid inside the accelerated tank the fluid hits the tank wall, can I found the force on tank wall if it is fluid structure interaction how can I couple this both, help me thanks |
August 23, 2016, 07:30 |
urosgrivc
Rep Power: 12 |
as Force = Pressure*area
You are able to transfere Pressure contour to structural via simple one way coupling. Yust drag the static structural on to CFX. inside structural new tab will apear that lets you import pressure contour, this will be your boundary condition. this will work only for one timestep or steady state. If you want to know the walue for force that is created by the fluid you can measure it in cfxpost; Force_x@location will give you the force in x direction on surface that you want ((fluid side) as it is integrated from fluid pressure on the wals and wiscous forces). |
pressure, sloshing, tank, wall force |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 14:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | ANSYS | 0 | July 22, 2016 14:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 14:39 |
About one-way Fluid-Structure Interaction, form structure to fluid !? | xq712000 | ANSYS | 0 | July 15, 2016 10:40 |
Fluid Structure Interaction using icoFsiFoam Problems | lr103476 | OpenFOAM Running, Solving & CFD | 79 | August 7, 2014 10:30 |
