August 19, 2016, 14:52 |
velocity vector in CFX post
Rep Power: 10 |
in free surface flow I want to sketch velocity vector . but it sketches both air and water velocity vector, how can I draw only water velocity vector.
August 20, 2016, 07:05 |
Rep Power: 144 |
Create a variable in CFD-Post of velocity*volume fraction. Then the velocity will be zero in the air section.
Or you can put a contour on the free surface and generate a user surface from it. Then plot velocity on the user surface and it will only be the water bit. There are probably other ways to do it if you have some imagination. |
CFX Pre & Post Startup Error | vigges | CFX | 12 | March 17, 2023 03:30 |
How to plot radial velocity in CFX 12.1 | Jerrica | CFX | 5 | February 11, 2015 11:33 |
Is it possible to obtain compressor map for axial compressor in CFX post ? | Irondome | CFX | 1 | June 16, 2013 06:24 |
Results of CFX Simulations | Sof_70_Usthb | CFX | 3 | July 9, 2011 06:15 |
Assign new variable in CFX Post | Ben | CFX | 1 | August 25, 2008 14:59 |
