August 15, 2016, 09:46 |
Turbo line @ 0.5 Span?
Brett
Rep Power: 14 |
Hi All,
Hope all is well in the CFD for turbomachinery community and you're having more luck than me! I've got a line appearing at 0.5 Span going from inlet to outlet that is of drastically different pressures than its surrounding cells. It shows up as the blue line at the inlet. Any thoughts on why this is? https://postimg.org/image/ye5gkqppb/ Inlet BC https://postimg.org/image/lhf4n7cll/ https://postimg.org/image/i10be5c9l/ Outlet BC https://postimg.org/image/g9u1iqw09/ https://postimg.org/image/pv28mrgg9/ Cheers!! Brett |
August 17, 2016, 04:56 |
Maxim
Rep Power: 13 |
how did you define the line? which settings are you using for the coloring of the cells?
try using absolute pressure for both and compare. also set the min. and max. to the same values in order to get the same color spektrum |
August 17, 2016, 10:36 |
Rep Power: 10 |
there is an option named "show chart location lines", uncheck it.
boundary condition, cfx 16.2, turbo machinery, turbogrid |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
k-omega SST flow over a cylinder | GP_FDU | OpenFOAM Running, Solving & CFD | 29 | January 15, 2016 16:06 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 12:37 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
