define Reynolds number in CFX
Old   August 14, 2016, 03:51
Default define Reynolds number in CFX
Tommy Chen
Tommy Chen is on a distinguished road
Hi I got a problem while using ANSYS CFX , the case I'm going to run is an aircraft cruising at 10 km high with mach=0.75. Usually when I was doing with the CFD code like SU2 or the inhouse code of our lab, I could easily set the reynolds number to be a certain value. Reynolds number is one of the three similarity parameters, with the other two as mach number and the scaled shape.
However, in CFX, is there a way for me to directly set the Reynolds number that could match the case ? If not, I guess I have to change the gas property to indirectly tune the Renolds number, then how could I do it ?
Tommy Chen is offline   Reply With Quote
Old   August 14, 2016, 08:41
CFX is a primitive variables solver. So it solves in pressure, velocity, temperature.
If you want to specify something as a Reynolds number you are going to have to define the velocity, density, length scale and viscosity it involves directly. Then to change the Re you change the parameters to get the new Re. In your case as this is probably an aircraft flying faster and slower - then I would just change the velocity.
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Calculation of Reynolds Number In CFX ashtonJ CFX 12 July 17, 2015 07:32
Question about momentum thickness Reynolds number Anna Tian Main CFD Forum 2 March 4, 2013 11:45
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
Reynolds number in CFX tuks CFX 0 May 25, 2005 02:16
