What variable should I output to get wall force?
Old   August 13, 2016, 12:27
Default What variable should I output to get wall force?
Pauli
Pauli is on a distinguished road
I am running a CFX v16.2 large & long transient multi-reference frame simulation. I want to minimize my transient result file storage space so I only output the variables I really want/need.
I need to have transient results for the wall force components in both the moving and the stationary domains. I am outputting the static and total pressure, density and velocity, and wall shear. Yet when I open a .trn file, I do not get force as a variable.
Here is my current output command snippet:
FLOW: Flow Analysis 1
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS: Transient Results 1
Include Mesh = On
Option = Selected Variables
Output Variables List = Absolute Pressure,Density,Total Pressure in Stn \
Frame,Velocity,Wall Shear
OUTPUT FREQUENCY:
Option = Timestep Interval
Timestep Interval = 1
END
END
END
END
Can someone please point out what I am missing. Do I need additional output parameters or is this some idiosyncrasy of how CFX processes wall data?
I ran a test where I used standard output for a few transient time steps. When I loaded one of those .trn files I was able to get wall force. So I am thinking I need an additional variable or two.
Thanks,
Pauli
Pauli is offline   Reply With Quote
Old   August 14, 2016, 08:43
I suspect you will need to include the pressure variable to get forces acting on surfaces.
Old   August 15, 2016, 12:02
Pauli
I tried outputting the static and total pressure in stn frame, density, velocity, and wall shear. I expected that was sufficient to compute wall forces. However, when I opened a .trn file, force was not available.
Old   August 16, 2016, 03:29
Jiri
Jiricbeng is on a distinguished road
Well, you can calculate the force on your own:
Fx = areaInt_x(Pressure)@surface + areaInt_x(Wall Shear)@surface
and Fy, Fz similarly.
The expression above is similar to force_x()@surface, however not exactly the same.
Jiricbeng is offline   Reply With Quote
Old   August 16, 2016, 03:39
Lance
Lance is on a distinguished road
Wouldnt it be
Fx = areaInt_x(Pressure)@surface + areaInt(Wall Shear X)@surface instead?
Because I think that integration in X of the whole wall shear vector is not the same as integration of the x-component of the wall shear vector?
Lance is offline   Reply With Quote
Old   August 16, 2016, 06:19
Jiri
Yes, I think you are right.
However if you compare
and
Fx = force_x()@surface
there is still very small difference, but I think it could be neglected
Old   May 15, 2018, 08:58
Dinar
Dinar is on a distinguished road
You just need to turn on the Output Boundary Flows option.
    RESULTS:
      Include Mesh = On
      Output Boundary Flows = All
      Output Variables List = Pressure,Velocity,Wall Shear
    END
Dinar is offline   Reply With Quote
cfx force output
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Full force and moment coefficient output Newfoamy OpenFOAM 6 March 17, 2010 04:19
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
