Calculate variance of velocities (eg.) in centrifugal impeller
Old   August 12, 2016, 14:17
Post Calculate variance of velocities (eg.) in centrifugal impeller
Raphael Kuckuck
Raku is on a distinguished road
Hello forum (as this is my first post),
I currently have the problem that I simulate a centrifugal compressor which has to be improved via using splitter blades.
One of my goals is to homogenize the exit-flow pattern to improve efficiency etc.
My approach is to calculate the variance of the velocities (Mach numbers, vorticity etc). Thus I need to have every cell's value for velocity (as the calculation of variance is somewhat like
\sigma² = 1/N \sum (x - x_m)²
where N defines the number of tangential "stripes" over which I calculate the mean value x_m.
x is the value of every single cell within my "stripe".
You can imagine these stripes as the tangential mixing of a stage interface (mixing interface).
To make it more comprehensible, I attached a picture of what I mean.
The question: How do I calculate a cell's value to insert it into my formula.
If you also know another method to summarize the degree of homogenity of a flow, please let me know
Thanks in advance!
Raku is offline   Reply With Quote
cell value, centrifugal compressor, variance
how to extract the components of radial and tangential velocities from pump impeller renyun0511 OpenFOAM Running, Solving & CFD 3 October 31, 2022 10:31
centrifugal pump Chalghoum CFX 18 April 16, 2014 07:37
Post - Angles alpha and beta in centrifugal compressor faivala CFX 0 August 28, 2012 20:23
CFX - Solidworks Flow, Impeller comparison aerospace_guy_ CFX 8 March 20, 2012 23:06
Calculate fluid velocities Sergio Feitoza Main CFD Forum 1 January 10, 2007 15:06
