August 1, 2016, 21:15 |
Interface, Memory, Nodes & RAM size
Jinwhan Ryuk
Rep Power: 13 |
one hundread heat transfer tubes, 5m long and 0.05m diamter If I want to solve this problem, how many RAM do I have to use? How can I know the number of interface nodes? Physics are simple. Hot gase goes into tubes and water flows aroud them. The geometry is not symmetry. I need to make full scale model.
August 1, 2016, 22:23 |
Rep Power: 144 |
You cannot estimate the size required from that description.
I would model a single tube and do validation and verification to ensure your mesh and settings are adequate for accuracy. Then you will be able to estimate what you need for the full thing. And while you are doing it you will probably realise that this sort of thing is usually better done as a reduced order model anyway. |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
