modeling of plasma actuator on axial compressor blade |
July 29, 2016, 09:36 |
mojtaba
Rep Power: 10 |
hi
i want to modeling plasma actuator in axial compressor blade with CFX, but i no have any idea to do it i choose rotor 37 naca for base geometry but don't know how apply plasma effect on it please help me |
July 30, 2016, 07:50 |
Rep Power: 144 |
CFX has no plasma model. You can model some aspect of plasma physics such as the flow and some electrical/magnetic field stuff, but the details of the interactions of the charged particles with the flow or fields cannot be modelled in CFX (well, at least not easily).
Are you sure CFX is an appropriate modelling tool for this application? |
July 31, 2016, 12:47 |
#3 | |
mojtaba
Rep Power: 10 |
it's my thesis |
July 31, 2016, 21:04 |
Rep Power: 144 |
As modelling plasma would be a major new feature for CFX - if it was easy to implement (such as by using some CEL expressions), do you think it would already be implemented and advertised as a feature?
But it depends on what features of plasma physics you are trying to include. What plasma physics are you trying to model? |
August 1, 2016, 12:14 |
#5 | |
mojtaba
Rep Power: 10 |
August 1, 2016, 21:40 |
Rep Power: 144 |
How does the plasma affect the reattachment?
August 2, 2016, 11:05 |
mojtaba
Rep Power: 10 |
August 2, 2016, 21:31 |
Rep Power: 144 |
How does it inject momentum in the boundary layer? Where does the energy for it come from?
August 3, 2016, 04:08 |
#9 | |
mojtaba
Rep Power: 10 |
http://www.sciencedirect.com/science...1f3324aedf9e23 |
August 3, 2016, 04:15 |
#10 |
Rep Power: 144 |
Wow, that's a neat idea.
You *might* be able to model this replacing the plasma with a mass source or a momentum source, assuming the plasma acts in a similar way. That is straight forward as it means you do not need to model any plasma physics. But you do need to tune the source to recreate the effect of the plasma. |
January 28, 2017, 13:07 |
#11 |
mojtaba
Rep Power: 10 |
thanks
i model the plasma effect in Fortran and now want to insert the plasma solution in Cfx, do any body have any idea? |
January 28, 2017, 17:01 |
#12 |
Rep Power: 144 |
What plasma effect are you intending to insert into cfx?
January 29, 2017, 12:12 |
#13 |
mojtaba
Rep Power: 10 |
January 29, 2017, 17:14 |
#14 |
Rep Power: 144 |
You can put the force in (presumably as a force per unit volume) with a momentum source term.
I am a bit puzzled about the velocity comment. If your plasma model gives velocity then why do you need CFD? |
plasma actuator modeling udf code error | ares0508 | Fluent UDF and Scheme Programming | 11 | July 27, 2019 02:31 |
Plasma modeling in openfoam | mvee | OpenFOAM | 1 | August 27, 2012 08:34 |
plasma modeling | miroslav1312 | FLUENT | 3 | August 18, 2011 12:28 |
modeling plasma | lucyli | FLUENT | 0 | November 19, 2008 04:14 |
3d axial turbine modeling | Eke | FLUENT | 1 | November 28, 2006 14:53 |
