Steam Condensation in pipe with Air interaction
Old   July 26, 2016, 13:36
Default Steam Condensation in pipe with Air interaction
dfranken
dfranken is on a distinguished road
I have the following error:
"In Analysis 'Flow Analysis 1' - Domain 'Default Domain': Equilibrium phase change in one phase in a multiphase run is not supported by the solver for this combination of thermodynamic states."
I am currently trying to set up a problem in where I have saturated steam entering a pipe which is already initialized with air. The steam then is suppose to interact with air and condense. The air is then pushed out of the pipe with the rest of the steam. I am trying a equilibrium solution. Here are some of my current settings:
Domain>Fluid and Particle Defintions>Air(Air at 25C)>Continuous Fluid
Domain>Fluid and Particle Defintions>H2Olg(Steam3vl)>Continuous Fluid
Fluid Models>Multiphase>Homogenous Model(checked)
Fluid Models>Heat Transfer>Fluid Dependent
Fluid Specific Models>Air>Heat Transfer Model>Thermal Energy
Fluid Specific Models>H20lg>Heat Transfer Model>Thermal Energy
Fluid Specific Models>H20lg>Components>Steam3l>Equilibrium Constraint
Fluid Pair Models>Air| H2Olg>Nusselt Number> 6
Do you guys have any suggestions? I have tried a non-equilibrium solution previously but I was getting an error that said that there cannot be more than 1 continuous phase in NE solutions. Also, this is my first post and I have had only about 1 month of CFX experience and am still learning.
Thank you in advance for your help,
Daniel
dfranken is offline   Reply With Quote
air, condensation model, multiphase, steam, water
Steam condensation on wall Dinesh Yadav Fluent UDF and Scheme Programming 0 April 12, 2014 04:39
steam condensation youyou Main CFD Forum 0 April 5, 2012 05:21
Heat Transfer in a pipe flow(hot air) Saima Main CFD Forum 0 January 17, 2011 08:08
Regarding Simulating steam flow in a pipe saravanakumar-kandasamy FLUENT 0 June 8, 2010 12:04
Tangential Air Flow in a circular pipe Scott Turner Main CFD Forum 3 January 31, 2005 15:59
