Extracting data along polylines in transient solution
Old   July 25, 2016, 06:11
Default Extracting data along polylines in transient solution
Albin Berglund
blidblid is on a distinguished road
I've made a transient simulation of a turbine rotor blade and as part of my analysis I am extracting data along polylines in the turbine shroud gap.
I've written a session script that iterates through my .trn files to extract the flow features along these polylines. The problem I have is that I only get null values after a few iterations. This is because the polylines do not follow the rotor blade.
To fix this, I've tried to get my polylines (which are defined by .dat files) to rotate with the rotor blade. And I have tried to use the rotor blade as a stationary frame. I can't get it to work. When I rotate polylines/mesh in CFX Post, it seems to be only be in the viewer, and not an actual alteration of the data. Is there any way to actually rotate anything in CFX Post? If not, is there any other way that I can extract flow features along a polyline that is stationary in reference to a rotating turbine blade?
Thanks,
Albin
blidblid is offline   Reply With Quote
Old   July 27, 2016, 03:05
Maxim
-Maxim- is on a distinguished road
Maybe if you created a polyline based on the "boundary intersection" with a blade, I would hope that the polyline rotates along with the blade.
I have not tested that yet but maybe it gives you a hint.
Here's a post from me where I described a solution to a similar problem:
http://www.cfd-online.com/Forums/cfx...tml#post596716
-Maxim- is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Animation of Fluent transient data saisanthoshm88 CFX 22 August 14, 2017 20:06
Animation of Fluent transient data saisanthoshm88 FLUENT 2 December 18, 2012 10:51
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
How to get the transient data ? Lee Siemens 2 September 8, 2003 04:57
