what are the boundary conditions for the propeller ?
Old   July 13, 2016, 02:39
Question what are the boundary conditions for the propeller ?
Mostafa
salamony1992 is on a distinguished road
Hello!
I am trying to put a small propeller behind airfoil (2D case), the model of the propeller will follow the actuatior disk theory. there is no propeller design yet, just a discontinuity to increase the flow momentum to produce thrust.
the picture is attached to be more clear.
it will be modelled as a square with air inlet and exit. the mass of air entered the propeller will gain pressure and go out to the domain again.
my question is:
what boundary conditions i shall set in the propeller enternce and exit??
how i can control the thrust required?
thanks in advance
salamony1992 is offline   Reply With Quote
Old   July 14, 2016, 07:11
The rear boundary should probably be an outlet with either defined static pressure or average pressure.
You control the thrust by varying the strength of the momentum source.
ghorrocks is online now   Reply With Quote
Old   July 14, 2016, 13:39
Mostafa
Thanx for your reply, but its not clear
U mean that the face near the trailing edge is pressure outlet?
Old   July 14, 2016, 20:03
The boundary face on the right side, labelled opening should probably be an outlet as I mentioned. An opening should work too if you want to go that way.
boundary conditions, propeller
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
