July 10, 2016, 11:00 |
Pressure higher than calculated value
Arun subramanian
Rep Power: 10 |
Dear friends,
I am trying to compress a simple cylinder with " total energy " option . I believe this is similar to adiabatic compression. PV^gamma = constant. . . . . . (1) Pinitial= 0.1 MPa, V=pi*r*r*L = 3.142*20*20*50 =62840 mm^3 Now I compress it till L=13.5 New V= 3.142*20*20*13.5 = 16967 mm^3 from (1) , P2=P1*(V1/v2)^gamma P2 = 0.6259 MPa In my CFX simulation , I get higher values like 0.78 MPa. At lower stroke lengths, I get almost perfect results. Also, I had specified a sinusoidal motion but I get something like in the figure below for higher stroke length. It works normally for small stroke lengths. Can someone please tell me what is the reason that this happens? |
July 10, 2016, 20:28 |
Rep Power: 144 |
Your error is almost certainly that you have not conducted a sensitivity analysis of the important variables. You must check that your convergence criteria, time step size and mesh are adequate to get accurate results. If you just guessed these parameters then you almost certainly have guessed wrong.
This is discussed in the FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
July 13, 2016, 09:22 |
Arun subramanian
Rep Power: 10 |
h0w d0 I res0lve this err0r?
July 14, 2016, 07:05 |
Rep Power: 144 |
That error message is for pitch change across GGI interfaces for rotating frames of reference. Why are you using rotating frames of reference on a piston compression model?
cfx, cylinder, pressure, total energy, transient |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 02:52 |
inlet pressure is higher than outlet pressure for fan | sivakumar | OpenFOAM Pre-Processing | 16 | December 30, 2017 15:16 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
Outlet pressure | aja1345 | FLUENT | 5 | August 18, 2015 12:02 |
pump outlet pressure higher than inlet pressure | jstan3 | FLUENT | 14 | February 14, 2014 00:44 |
