June 25, 2016, 17:46 |
Calculation Error in USER subroutine
Asif Zubair
Hi ,
I am new to the field of ANSYS and CFD as I am doing my maser thesis on WIND turbine simulation. I am facing a very weird type of problem and need your help. It is a problem with one of the USER CEL subroutine . I am using a subroutine to divide the blade in a no of elements .the blade is divided in a number of radial segments. The radial positions of these blade segments are defined by one dimensional arrays RI and RJ Later in the program, I got some error and I traced it back to the subroutine that it is not giving me correct values of RJ . Then I displayed the results of RJ using the same loop in which it is calculated (attachment 1.png). Fortunately the values of RJ were correct. Then in the same routine, immediately after that loop, I started another loop to display the values of RJ again and unfortunately they were not correct(attachment 2.png). Hence I came to know that here is the error originating. I have rechecked the program and seemingly there is no error and the error is originating somewhere inside the subroutine. I know it is a programming thing but I have posted it in CFX forumn because i am am using another program on fortran without CFX to calculate wind turbine performance using same subroutine and this problem is NOT coming in that program. So I assume it is related to CFX and its Fortran compiler or the memory management system , but I am not sure . I need help in this matter as I am stuck in it for past few days. The subroutine is as follows SUBROUTINE LLPOINTS (PI,PREC,R,HUBRAD,M,RI,RJ) !Inputs : Pi, Prec, R, Hubrad !output : RI, RJ INTEGER:: M REAL::PREC,R,HUBRAD REAL:: RI(41),RJ(41),DJ(41) INTEGER :: J character*100 ::string1, string2, string3 CALL MESAGE( 'WRITE', 'subroutine INIT START' ) CALL MESAGE( 'WRITE', "RI RJ) DO J=1,M+1 IF (J.LT.M+1) THEN RI(J)=0.5E+00*(1.E+00+HUBRAD/R)-0.5E+00*(1.E+00-HUBRAD/R) &*COS((J-0.5E+00)*PI/M) ! RRI(J)=RI(J)*R RJ(J)=0.5E+00*(1.E+00+HUBRAD/R)-0.5E+00*(1.E+00-HUBRAD/R) &*COS((J-1.E+00)*PI/M) !RRJ(J)=RJ(J)*R IF (ABS(RI(J)).LT.(1/PREC)) THEN STOP ENDIF ELSE RJ(J)=1.E+00 END IF write (string1,*) RI(J) write (string2,*) RJ(J) CALL MESAGE( 'WRITE', string1//' '//string2) END DO CALL MESAGE( 'WRITE','ri rj') do j =1,m write (string1,*) RI(J) write (string2,*) RJ(J) CALL MESAGE( 'WRITE', string1//' '//string2 ) end do CALL MESAGE( 'WRITE', 'subroutine LLINE OK' ) END SUBROUTINE |
June 27, 2016, 10:17 |
Rep Power: 16 |
You don't appear to have defined PI in your routine, but anyway you should really be using IMPLICIT NONE to ensure that all variables are explicitly defined.
If you are compiling using cfx5mkext on windows, I think you can also use the switch -warn to alert you to any undefined or unused variables. |
June 27, 2016, 20:52 |
Asif Zubair
Thanks for the reply . Yes I have not included implicit none in any of the subroutines. I have included it and then I have got a lot of errors related to variable declaration. Can you tell me how to switch- warn ? I have no idea regarding it . Further, when I have resolved all the errors related to variables after incorporating implicit none , at the very end of compilation , I have received an error stating
Error:unresolved external symbol LLINE referenced in function ACD_Dp. This error was not present before using implicit none. ACD_Dp is the main USER CEL function that further calls LLINE subroutine . In the LLINE subroutine, LLPOINTS subroutine mentioned above in my question is present. |
June 29, 2016, 04:45 |
Rep Power: 16 |
You add it to the command line when you use cfx5mkext to build your library, for example,
cfx5mkext *.F -name mylib -warn Not sure why you would be getting unresolved symbol errors if you have called you lower subroutines correctly. Have you declared any functions? |
User Subroutine | A. Said | CFX | 9 | March 7, 2008 16:49 |
FLUINJ USER SUBROUTINE! | Spyridon | Siemens | 8 | May 22, 2002 06:31 |
user subroutine of inlet boundary | raymond | Siemens | 4 | December 6, 2001 06:44 |
USER SUBROUTINE IN FLUENT??? | tim | Main CFD Forum | 0 | April 24, 1999 05:19 |
CFX User Subroutine Archive | David Creech | Main CFD Forum | 0 | March 17, 1999 13:41 |
