Application of heat source for 1 second in a 3 seconds transient analysis
Old   June 23, 2016, 19:24
Default Application of heat source for 1 second in a 3 seconds transient analysis
Shahid Parvez
shahpar73 is on a distinguished road
Hi
I want to run a transient heat transfer analysis for 3 seconds in which a heat flux on a boundary (in W m^-2) is to be switched on after 1s and then switched off after 2s. The purpose is to see how the surface cools down. How to set it in CFX-Pre.
shahpar73 is offline   Reply With Quote
Old   June 23, 2016, 20:51
Some options:
Use a CEL if function
heatflux = if(t>1[s],if(t<2[s],100[W],0[W]),0[W])
or
heatflux = step((t-1[s])/1[s])*step((2[s]-t)/1[s])*100[W]
or use a 1D interpolation function
Old   June 25, 2016, 09:08
Shahid Parvez
Thanks Glenn. I really appreciate your help.
(1) In my case, the heat source is initialized from a "Profile data", lets say with the name "HeatSource". can I simply replace 100[W] with "HeatSource" in "step" function?
(2) "if" function is simple, so how to use "HeatSource" with "if".
Old   June 25, 2016, 09:42
I have never done that with profile data but I think you can do it. Give it a go and see if it works for you.
Old   September 3, 2016, 02:21
Shahid Parvez
"if" function didn't work with profile data (may be I am not using it correctly); however, "step" function did work. The command is follow;
heatflux = step((t-1[s])/1[s])*step((2[s]-t)/1[s])*HeatFlux
Where HeatFlux is initialised as profile data and then defined as user function.
Thanks Glenn for the help.
Old   September 3, 2016, 09:00
I think the if function was introduced in ANSYS V15. If you have an older version you will only have the step function available.
heat sources, transient
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
Transient spacial dependent heat source Kumudu OpenFOAM Running, Solving & CFD 0 October 28, 2013 12:02
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
