Zig Zag Streamlines
Old   June 23, 2016, 07:55
Default Zig Zag Streamlines
aakash
aakash hassan is on a distinguished road
Hello everyone, I am studying flow of air inside solar chimney. Streamlines show irregular pattern of flow but velocity is still high. Does this mean that there is turbulence in flow and mass flow rate has decreased because all the streamlines are not flowing through the chimney? I've attached image file so can get idea. Any suggestion will be appreciated.
aakash hassan is offline   Reply With Quote
Old   June 24, 2016, 09:57
Maxim
-Maxim- is on a distinguished road
it looks like they bounce of that intersection plane. My guess is that you haven't set up the configuration correctly since you probably want to get the result for a 360° chimney. How did you define your boundary conditions/walls?
Please share your out-file.
-Maxim- is offline   Reply With Quote
Old   June 25, 2016, 03:42
aakash
Thanks a lot Maxim for your reply. I think this bounce isn't due to intersection plane because streamlines show a smooth flow at small slope. These are results when collector slope is increased.
Old   June 25, 2016, 04:58
This looks like it has not converged fully yet
Old   June 25, 2016, 10:21
aakash
Thanks Ghorrocks for reply, Actually solution got converged when i used first order accuracy,but for 2nd order, residuals showed problem in converging and didn't fell upto converging criteria. But residuals got stable after 1500 iterations, and solution was not changing much with successive iterations. And continuity residual approached almost 1e-3 and energy reached below 1e-6. So i assumed that solution has converged.
Old   June 25, 2016, 21:54
You can't assume that! Read the FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Zig Zag Maneuvering of Vessel Myra Satuka Fidelity CFD 0 August 28, 2014 02:05
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 11:13
[General] Problems with streamlines for 2D porous media flow simulations twophaseflow ParaView 4 February 11, 2014 15:32
Streamlines under Moving reference frame; Spiral streamline from Tecplot aiqch Tecplot 2 October 30, 2009 00:27
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 14:33
