is it converged?
Old   June 22, 2016, 22:58
Default is it converged?
uvvis
uvvis is on a distinguished road
uvvis is offline   Reply With Quote
Old   June 22, 2016, 23:46
Opaque will become famous soon enough
Very likely is not converged.
If you change the range of the plot for the imbalances, and monitor the last 50 iterations you may see how well the conservation targets are satisfied.
Opaque is offline   Reply With Quote
Old   June 23, 2016, 00:20
uvvis
Thank you for replying. I did and pic is attached. is it acceptable below 5 %? How can i improve convergence? I also refined mesh but situation is same.IMG_6154.jpg
Old   June 23, 2016, 01:17
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Monitor other variable, temperature out, average temperature, mass flow in - mass flow out, pressure out. You HAVE to monitor what you are interested in... don't rely on those curves only. From the picture you showed try to refine your mesh if your case is fine...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 23, 2016, 04:08
uvvis
diamondx Thank you!
Please see the the monitor points for my interest (pic attached).
Old   June 23, 2016, 08:14
This question is discussed in this FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Initializing transient analysis using static analysis in two-way FSI simulation Daniel_Khazaei ANSYS 50 September 12, 2017 11:56
Unable to get converged solution using SimpleFoam jr33 OpenFOAM Running, Solving & CFD 6 December 12, 2016 05:48
simpleFoam: divergence after resuming a converged job pbalz OpenFOAM Running, Solving & CFD 12 September 20, 2016 02:15
New sixDoFRigidBody BC working with laplaceFaceDecomposition Ya_Squall2010 OpenFOAM Running, Solving & CFD 13 April 17, 2013 03:04
Solution converged, and then diverge again. jrg FLUENT 2 April 2, 2013 00:10
