Heating efficiency through solid surface
Old   June 20, 2016, 03:26
Default Heating efficiency through solid surface
kjetil is on a distinguished road
Dear cfx people,
I am setting up a simple problem to find the heat transfer coefficient / heating efficiency through forced convection on a plain surface, versus using some means to disturb the boundary layer and generate near wall turbulence to aid increased heat transfer. What would be the best way to evaluate the heat flux on the opposite solid side of the plain surface? areaInt() of Wall Heat Flux may perhaps be a an option? (My original thought was to use the overall surface temperature.)
File Type: png 2016-06-17 14_14_55-A_ Geometry - DesignModeler.png (61.4 KB, 6 views)
kjetil is offline   Reply With Quote
Old   June 20, 2016, 08:18
Are you looking for the steady state heat flux? If that is the case then there is no need to model the solid as the heat flux from the fluid = heat flux out the solid, so just model the fluid and save the hassle of modelling the solid.
And yes, areaInt(Wall Heat Flux)@... sounds like a good function for this - assuming you are applying a constant temperature boundary condition (or a convection BC).
Old   June 20, 2016, 08:36
Right. Yes, steady state heat flux is sufficient.
Another thing - heating is performed with a Variable Composition gas mix from a fixed circular inlet. Would you say it is possibly to calculate Heat Flux over this inlet as well similarly to the wall surface mentioned above? I am not quite sure how CFX would treat these two different type of patches, where one involves advection.
solid to solid surface contact honeybunch FLOW-3D 0 May 31, 2016 04:32
[ICEM] surface boundaries from solid kostast88 ANSYS Meshing & Geometry 0 November 23, 2013 10:10
[Other] Extruding surface into solid rakadit ANSYS Meshing & Geometry 3 May 4, 2012 01:30
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
[Commercial meshers] define a porous surface with solid material on it in Gambit s.sami OpenFOAM Meshing & Mesh Conversion 0 July 26, 2010 17:51
