Assessing steady state results for unsteady flows
Old   June 10, 2016, 07:20
Default Assessing steady state results for unsteady flows
siw
Stuart
siw will become famous soon enough
I know this is very simulation dependent but it will be useful to have comments from the experienced CFX community.
My model is of an internal flow (ducts and filters) which I have simulated as steady state with a range of mass flow rates to plot the system pressure loss against the fan performance curve; the fan is downstream of my system and not included in the model. However, for all the simulations the residuals and monitor points (velocity and pressure at many points in the system) show the flow is unsteady. But I do not have enough time to simulate any transient cases; the timestep and endtime would be choices to make as well.
As this is a common situation with industrial CFD (complex flowfields but little time to solve them suitably) then how do others assess steady state solution results for unsteady flows? For example; I need to report the pressure drop across the system but the outlet pressure is unsteady, the inlet is just atmosphere. Strictly, the monitor point plot is not giving a fluctuating pressure to take a max/min/mean from.
Thanks.
siw is offline   Reply With Quote
POPULATION BALANCE MODELING (PBM) in Steady State osha Fluent Multiphase 1 June 18, 2022 08:22
unsteady state to steady state neetu kumari OpenFOAM 4 June 14, 2016 19:16
Time Increment Significance in Steady state FEM CFD solvers? Abhya Main CFD Forum 1 October 14, 2015 21:07
Steady state simulation with transient partilcle tracking mali28 FLUENT 2 February 7, 2013 15:25
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
