June 4, 2016, 12:12 |
Mixing Tank simulation
Rep Power: 10 |
I am trying to simulate the flow in a mixing tank with a rotating impeller. There is a free surface in the top, so I use a homogeneous model of water and air. I have done the tutorial of CFX that deals with a mixing tank and since my problem is similar, i don't think the physics is the problem. However since the geometry step is skipped in the tutorial, i think i might be missing something there. My geometry process is as follows:
-Draw the tank -Draw the impeller (in a different geometry file) -Open the tank geometry file and import the impeller. -Translate and rotate the impeller into an appropiate location. -Set both bodies as fluids. -Continue meshing. The residuals initially go down smoothly but then the solution diverges (see attached image) http://postimg.org/image/bs2bs8m0b/ Things i have tried: -Using other turbulence models besides k-e (as in the tutorial). -Using lower or higher timesteps. -Refining the mesh. -Doing a transient run. -Using a lower rotational speed (currently using 100 RPM). Please, anyone has an idea what might be wrong? |
June 5, 2016, 07:19 |
Rep Power: 144 |
What happens if you keep running it? Sometimes there is a temporary increase in residuals as the flow establishes and it just needs time to work its way through.
Solid object falling in water tank simulation | cassini83 | CFX | 3 | August 9, 2021 18:05 |
Multiphase Mixing Tank | afonsoal | CFX | 0 | April 27, 2014 23:07 |
Tank Mixing Problem | davidleinster | CFD Freelancers | 6 | June 18, 2013 11:50 |
Meshing industrial scale mixing tank | mlbontbs87 | FLUENT | 0 | April 26, 2011 16:18 |
3D modelling for mixing tank | boonho | FLUENT | 2 | March 22, 2005 05:54 |
