June 3, 2016, 03:08 |
CFX5post.exe not found error
Girish Gaikar
Rep Power: 10 |
I m done with geometry mesh setup and solution,but as soon as i try to open results i get an error sayin,CFX5POST.exe not found.
This is the actual error, Error running C:\Program Files\ANSYS Inc\v150\CFX\bin\cfx5post.exe -control-port 52655: The system cannot find the file specified |
June 3, 2016, 07:33 |
Maxim
Rep Power: 13 |
how do you open Post? Via command line? You might have to set the path in " " because of the spaces in the name (between Program and Files).
"C:\Program Files\ANSYS Inc\v150\CFX\bin\cfx5post.exe" Assuming of course that Post is properly installed in that directly. |
June 3, 2016, 14:05 |
Girish Gaikar
Rep Power: 10 |
i just double click on results and this error appears.
June 6, 2016, 03:30 |
Maxim
Rep Power: 13 |
can you open Post manually? from the folder?
If yes, try to load your result file manually - at least for now... |
June 6, 2016, 03:40 |
Girish Gaikar
Rep Power: 10 |
And can you tell me how to do that?
June 6, 2016, 03:41 |
Girish Gaikar
Rep Power: 10 |
i tried reinstalling but it didnt help
June 6, 2016, 03:55 |
Maxim
Rep Power: 13 |
Go to C:\Program Files\ANSYS Inc\v150\CFX\bin\ and open cfx5post.exe (double-click).
That initial error message also says something about a port. Maybe your firewall or anti virus program is blocking workbench from opening post. The windows firewall asked me when I launched programs from the workbench for the first if I want to allow it. Did you allow it? |
June 6, 2016, 07:20 |
Girish Gaikar
Rep Power: 10 |
I disabled firewall actually..byt i didnt disable my antivirus.I will disable and i will try it again.I ll get back to you.
June 7, 2016, 13:19 |
#9 |
Girish Gaikar
Rep Power: 10 |
It turns out that my antivirus had corrupted my setup files itself.I downloaded new files and it worked.Thanks!
June 8, 2016, 01:04 |
#10 |
Maxim
Rep Power: 13 |
that Ansys software is indeed an evil virus
April 3, 2020, 04:05 |
#11 | |
Deadeyes
This is what the error says cfx5post.exe -control-port 50657: The system cannot find the file specified I searched for cfx5post.exe in the bin folder as well, but i couldn't find any executable file. Thanks in Advance |
April 4, 2020, 10:53 |
#12 | |
Deadeyes
Hey i fixed it, all I needed to do was unistall ANSYS, clear all the AppData, temp files then disable firewall, disable my antivrus, then I installed it again. |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
