Pump's Torque in CFD simulation is higher than experience.
Old   May 31, 2016, 02:23
Default Pump's Torque in CFD simulation is higher than experience.
ngoc tran bao
ngoc_tran_bao is on a distinguished road
Dear All, I have a challenge with the torque in my pump simulation. At Design Flow rate, the torque calculated on impeller of pump in CFD simulation is much higher than torque measured by experiment, 90Nm compared with 73 Nm. It is obvious that in simulation we can not account for all factors as reality, so I believe that because of lower resistance, torque in CFD should be lower than that of experiment. In my simulation, impeller consists of Hub, Shroud and 7 blades and I calculate torque on impeller for Z axis (used both monitor point in Solver and Function calculator in Post). Does anybody have ideas to explain me why there is an existence of unreasonable result? Thank you in advance.
ngoc_tran_bao is offline   Reply With Quote
Old   May 31, 2016, 02:33
urosgrivc
urosgrivc is on a distinguished road
inappropriate boundary conditions, or mesh, or other setings
In cfd it is almost always the user`s fault as computer is just a number crunching machine it can only do what you say it to do.
More details will be needed to figure out what is wrong
urosgrivc is offline   Reply With Quote
Old   May 31, 2016, 02:58
Maxim
-Maxim- is on a distinguished road
That's quite interesting because in my simulations, the calculated CFD torque is always lower from what we would expect.
Maybe you can share more information about your setup so that we can have a look?
-Maxim- is offline   Reply With Quote
Old   May 31, 2016, 03:03
ngoc tran bao
Thank for your replies,
As for BC, I set total Pressure at Inlet = 0.1 Mpa;
Variable Mass Flow rate at Outlet From 60 - 180 m3/h (Q design =120);
Rotation = -1750 RPM (Z axis)
Smooth wall for all suction, discharge walls;
Reference Pressure =0 atm;
Physical time step =1/W.
I hope those Information useful.
Old   June 1, 2016, 03:36
Maxim
can you please post your ccl and/or out file?
Have you checked the typical questions such as:
Has your simulation converged? Are the imbalances under 1%? Etc.
Old   June 1, 2016, 04:27
ngoc tran bao
centrifugal pump 1.txt
this is CCL file. As for convergence and imbalance, both are satisfied. The simulation gets convergence at timestep of 150, and imbalances at all domain are under 1%.
Old   June 7, 2016, 00:00
ngoc tran bao
Hello, do you have any suggestion about very high torque in this CFD simulation? A higher torque in simulation results in a lower pump effeciency compared with experiment efficiency. That is not reasonable. I am looking forward to hearing opinions from you.
Data Center Simulation scottg Main CFD Forum 11 October 17, 2024 02:22
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 13:26
CFD simulation with sliding meshes ivanddd FLUENT 0 April 16, 2011 18:26
Peripheral pump CFD simulation Nevel Main CFD Forum 0 October 8, 2009 02:09
What do you CFD guys do during a long simulation running? bearcat Main CFD Forum 5 July 23, 2009 09:08
