Troubleshooting with simple GE90 engine model (Isolated Volumes) |
May 30, 2016, 18:15 |
Yoshi Toshi
Rep Power: 10 |
Currently making a simple model of the GE90 engine and here is a picture of all the parts of the engine
engine.png The entire engine is put in an enclosure btw. So when I try and run the solution, I get the error that I have 3 isolated bodies. I have tried to figure out what those bodies are using the results but have absolutely no idea where the problem is occurring, partially because I am not fully able to understand how to look for isolated bodies. Here are two pictures I took of a plane bisecting the enclosure: isolatedvolume.pngisolatedvolume2.png I have triple checked in the setup that I have defined an interface for every interacting face that requires one. The shaft, separator and engine frame are solids while the bypass and core flows are fluids. Any ideas where the problem might be located? I can provide further pictures if anyone wants them! |
May 30, 2016, 22:23 |
Rep Power: 144 |
You almost certainly have a problem in your interfaces. Give them a very close look.
June 1, 2016, 15:06 |
Yoshi Toshi
Rep Power: 10 |
Remade the entire model along with new mesh, boundary conditions and interfaces, still getting the same error message haha
Do you know how to read the graph? What does red/green represent? Couldn't find anything in the user manual about it |
June 1, 2016, 21:04 |
Rep Power: 144 |
It has labelled the isolated volumes 1, 2 and 3. So they will be red, green and blue. This is so you can see what the problem is.
June 2, 2016, 05:45 |
Rep Power: 14 |
I would guess your wall bc(s) contains faces connecting the fluid domains to each other.
interface, isolated, isolated bodies, mesh |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 10:29 |
Liquid rocket engine non-premixed combustion model | Erik | FLUENT | 2 | November 28, 2013 15:09 |
turbulence model in internal combustion engine | George | Main CFD Forum | 0 | December 4, 2006 19:01 |
CFD on a simple moving engine | shreen | Main CFD Forum | 3 | December 7, 2005 13:07 |
CFX model of diesel engine intake & compression | Gareth Floweday | CFX | 5 | May 2, 2002 04:54 |
