May 27, 2016, 08:49 |
Iteration number - flow rate relation
Rep Power: 10 |
Hi all,
I'm trying to observe behavior of a wing due to the different flow rates, so that i need to solve different working conditions. I start my calculations but when the analysis has completed, for every working conditions i go back to setup and changing flow rate and start again, because of that i can not leave PC alone. My analysis converging about 60-70 iterations so i think that if i change my flow rate due to iteration number, i can calculate more than one situation and i can read values from solver manager graph. I tried to write an expression but i couldn't figure out how to write for such that problem. (Probably because i'm new on CFD (Really new!!)) Can anyone help me? or show me a way? I need to change my flow rate based on iteration number. For example; iteration number 0 to 100 => flow rate = 2 [kg s^-1] iteration number 100 to 200 => flow rate = 3 [kg s^-1] iteration number 200 to 300 => flow rate = 4 [kg s^-1] . . . and goes on. thanks in advance and sorry for my english. |
May 27, 2016, 09:48 |
Rep Power: 144 |
This sounds like a really bad idea to me. A CFD simulation should progress to convergence and produce a single result. There are many different ways to get runs to queue up and run automatically and it is really easy to do:
* Batch/script file - the change to the conditions can be done by a CCL file written to the definition file by the command line cfx5cmds. Then start the run with cfx5solve. Then repeat for all the combinations you want to do. * Use the parametric modelling in workbench * Use a batch scheduling system like PBS, LSF (OK, this is not such a simple approach - I suspect if you used these systems you would not be asking this question But the other two options are very simple) |
May 27, 2016, 09:50 |
Rep Power: 144 |
Here's an example batch file which would do it:
cfx5cmds -def <def file> -text <CCL file 1> cfx5solve -def <def file> cfx5cmds -def <def file> -text <CCL file 2> cfx5solve -def <def file> cfx5cmds -def <def file> -text <CCL file 3> cfx5solve -def <def file> This will do 3 runs, one after the other (so only using a single license at any time) using 3 different setup CCL files. |
May 27, 2016, 10:55 |
Rep Power: 10 |
Thanks a lot Glenn,
it's also seems to a stupid idea but as i told i'm very new about CFD, i will try to solve as you suggest i also find a solution which i try to do, here is the link for anyone who needs http://www.padtinc.com/blog/the-focu...essions-part-4 Last edited by helvas; May 30, 2016 at 02:48. |
May 28, 2016, 06:58 |
Rep Power: 144 |
Putting ramping or stepping functions in CEL is very useful and it is good you have a tutorial on it. But using it as a method of doing multiple simulations in a single simulation is not wise. I did not answer the question on ramping the CEL as a case of the XY problem (http://xyproblem.info/) - the real issue is how do you effectively run multiple simulations.
May 30, 2016, 02:30 |
#6 | |
Lance
Rep Power: 22 |
cfx5solve -def <def file> -ccl <CCL file 1> cfx5solve -def <def file> -ccl <CCL file 2> cfx5solve -def <def file> -ccl <CCL file 3> |
May 30, 2016, 03:57 |
Rep Power: 10 |
Dear Glenn, Lance;
Thank you for advices, I made a search for parametric modelling and Batch/script file, and using parametric modelling seems to me very easy and i prepared my setup parametric. I have solution now, thank you very much. |
expression, flow rate, iteration, optimization |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 06:58 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 11:40 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
