May 23, 2016, 13:40 |
add two area around Cylinder in ansys
S.cheraghian
Rep Power: 10 |
In Ansys-APDL media, we can add two areas with Add instruction. So in non-Cylindrical volumes we add many areas easily too. But in Cylindrical Volumes we have to changing WP to add sidelong areas.
Now my question is : How can we do it? it means How can we add two areas around a Cylinder or around of any Cylindrical volumes? And What changes must be do in WP system? |
May 24, 2016, 02:23 |
urosgrivc
Rep Power: 11 |
Although this was wery hard to understand I will try to answer anyway.
If you want to have multiple areas on the surface of a cilinder (or any other object) you can easily do that in DESIGN MODELER. The function is called IMPRINT FACE. First you need to unfreeze the body so you can work on it. Than you make a sketch so you can set a line (or what ever you like to imprint on the surface of the cilinder) Than EXTRUDE it and select an imprint face comand. Those lines that you draw in the sketch will than divide the surface into multiple surfaces. |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 03:19 |
how to use UDF to obtain the thred of the interface between the liquid and the wall? | hellowqy | Fluent UDF and Scheme Programming | 8 | December 17, 2015 11:03 |
[ANSYS Meshing] uniform mesh, cylinder with a cut | Matiasi | ANSYS Meshing & Geometry | 5 | June 8, 2015 16:08 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 04:56 |
