Unexpected CFX_SOLVER license error in ANSYS-CFX FSI Simulation |
May 22, 2016, 10:47 |
Pranjal Singh
Rep Power: 11 |
Hi there!
I am trying to run a simple 2-way FSI problem of flow through a flexible tube. The problem is that I can seamlessly run ANSYS and CFX parts separately but the FSI is not running. I have an academic license for separate and FSI both but FSI simulation is giving this error. The main problem I see is the error that CFX_SOLVER license expired the moment I ran the simulation. Which is not the case since I can run the uncoupled simulation fine just after that. I have about 55000 nodes in the model which is below the cap. Please help! Code:
+--------------------------------------------------------------------+ | Job Information at Start of Run | +--------------------------------------------------------------------+ Run mode: parallel run (Platform MPI) Job started: Sun May 22 19:09:57 2016 Connecting to the following master process: Host Name : DELL Port Number : 56292 +--------------------------------------------------------------------+ | License Information | +--------------------------------------------------------------------+ License Cap: ANSYS CFX Solver (Max 128K Nodes) License Cap: Parallel ANSYS LICENSE MANAGER ERROR The license CFX_SOLVER expired on 2016/05/22 19:09:45. License ID: License checkout failed. The license CFX_SOLVER expired on 2016/05/22 19:09:45. +--------------------------------------------------------------------+ | ERROR #001100247 has occurred in the subroutine . | | Message: | | | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked | | out: | | | | ANSYS CFX Solver (Max 128K Nodes) + Parallel | | | | Please carefully examine the error message output above and check | | that: | | | | 1) The license server is specified correctly and is running. | | | | 2) An appropriate license is available for checking out. | | | | These problems can be checked using the ANSYS Client ANSLIC_ADMIN | | utility. For further troubleshooting information please consult | | ANSYS, Inc. Licensing Guide. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | ANSYS Solver terminated with return code 3840 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The results from this run of the ANSYS solver have been written to | | F:\Pranjal\2. Fluid\CFX\v2_pending\dp0_CFX_2_Solution_2\Fluid Flow | | CFX_003.ansys | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | F:/Pranjal/2. Fluid/CFX/v2_pending/dp0_CFX_2_Solution_2/Fluid Flow | | CFX_003: | | | | pids | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | For CFX runs launched from Workbench, the final locations of | | directories and files generated may differ from those shown. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. |
May 23, 2016, 03:21 |
Maxim
Rep Power: 13 |
contact your system/license admin of your school. To me, that seems more straight forward than letting us guess what might be the cause...
May 23, 2016, 03:37 |
Lance
Rep Power: 22 |
The message:
The license CFX_SOLVER expired on 2016/05/22 19:09:45. seem to indicate that your license for ANSYS CFX Solver (Max 128K Nodes) + Parallel has expired? Are you sure you still have a valid license? Have you tried to run in serial? |
May 23, 2016, 05:29 |
Pranjal Singh
Rep Power: 11 |
Thanks for the replies everyone. Both the suggestions were helpful. The problem is solved. The multiphysics and some other licenses were being upgraded at that time so I was unable to run the simulation. Although I checked the licenses at that time... but don't know why they were showing available. This resulted in all the confusion!
Thanks again. |
November 27, 2017, 10:15 |
VIKAS KANNOJIYA
Rep Power: 11 |
I am having the same problem, please tell me how to solve it.
January 10, 2018, 22:36 |
Ian
Rep Power: 13 |
i have same problem in transient simulation by ansys 14.5, this is error information, i copy cfx pre to other computer that the transient can run, ansys version is same ,but why?
| ERROR #001100247 has occurred in subroutine . | | Message: | | | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked | | out: | | | | ANSYS CFX Solver (Max 128K Nodes) + Parallel | | | | Please carefully examine the error message output above and check | | that: | | | | 1) The license server is specified correctly and is running. | | | | 2) An appropriate license is available for checking out. | | | | These problems can be checked using the ANSYS Client ANSLIC_ADMIN | | utility. For further troubleshooting information please consult | | ANSYS, Inc. Licensing Guide |
January 12, 2018, 03:53 |
Rep Power: 144 |
The error message explains exactly what the problem is. It cannot check out a solver license. So somebody else has the license, you are not connected to the license server or the license has not been released properly from a previous run or you do not have that license.
February 6, 2018, 08:25 |
Ansys cfx
Ahmed osman
Rep Power: 8 |
hello I was tried to build FSI by using CFX with system coupling but the CFX does not connect with system couple I was tried by using to version 14.5 and 16
Can anyone give me some help? |
February 6, 2018, 17:43 |
#9 |
Rep Power: 144 |
There are lots of tutorials for FSI and system coupling, even for older versions of CFX, on the ANSYS Customer webpage. If you are a student and you cannot access that there is reduced number of tutorials on the ANSYS student webpage. So have a look there and do the tutorials.
April 13, 2018, 10:25 |
how to fix it?
#10 |
invincible
Rep Power: 10 |
License error
April 13, 2018, 11:43 |
#11 |
Gert-Jan
Rep Power: 28 |
This is the CFX-forum, whereas you use fluent. So ask your question in that forum.
And don't hijack someone else's post. Create a new one for your own. |
fsi 2-way coupling, license error |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 10:16 |
what is 'license cap: ANSYS CFX solver(introductory)'? | itsqi7 | CFX | 1 | April 29, 2013 10:17 |
how to reatart a ansys cfx FSI? | cyy | CFX | 0 | July 3, 2012 23:17 |
FSI Simulation unsing ANSYS Multifield | k_buz | CFX | 2 | April 6, 2009 18:40 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
