The ANSYS CFX solver exited with return code 1. No results file has been created |
May 20, 2016, 22:31 |
Anonymous
Rep Power: 10 |
Hi
I have been trying to solve the velocity of an extruded rectangle. I did everything up until Setup and when I tried to solve it this error came up. Anyone has suggestions to what I could do? ERROR #002100048 has occurred in subroutine SU_BNEXT. | | Message: | | All vertices for a fluid domain lie on boundaries. This is | | considered to be a fatal error because control volume gradients | | cannot be calculated, leading to serious discretization error. | | | | A common cause for this error is a mesh which is only one | | element thick, without symmetry or 1:1 periodicity on the lateral | | boundaries. If you have this situation, and the domain is | | two-dimensional, please change the lateral boundary conditions | | to symmetry or 1:1 periodicity. Alternatively, for | | three-dimensional simulations, please ensure that your mesh | | has at least two elements across. | | | | Execution is terminating. This error message can be bypassed by | | setting the expert parameter 'boundary vertex check = f', but | | be aware that doing so may lead to significant solution error. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | For CFX runs launched from Workbench, the final locations of | | directories and files generated may differ from those shown. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. |
May 21, 2016, 07:04 |
Rep Power: 144 |
The error message is very clear, tells you exactly what the problem is and how to fix it. So my suggestion would be to read the error message and do what it says.
May 22, 2016, 22:15 |
Anonymous
Rep Power: 10 |
I just need help interpreting what the message means. Yes, I did read the message but still don't know how to do it.
May 22, 2016, 22:46 |
Rep Power: 144 |
You have a domain where all the nodes lie on the boundary - so no internal nodes. You can only do this under a limited set of circumstances.
If you are intending doing a 3D simulation the fix is to remesh so that you have internal nodes in the domain. If you are intending doing another type of simulation then please explain what you are trying to do. |
May 22, 2016, 23:00 |
Anonymous
Rep Power: 10 |
So basically so far I have drawn a rectangle, then i extruded it. I applied a fine mesh (i tried medium and coarse before same errors), then I created an inlet boundary with velocity of 0.00333 m/s, then I created an outlet with 0 Pa pressure. I also modified the density and viscosity.
So if that's the case, where can I go to fix the internal nodes in the domain? |
May 23, 2016, 01:24 |
Rep Power: 144 |
nodes = mesh. So you need to fix the mesh.
If you can't find the problem post an image of your mesh on the forum. |
May 23, 2016, 01:54 |
Anonymous
Rep Power: 10 |
May 23, 2016, 03:16 |
#8 | |
Maxim
Rep Power: 13 |
This doesn't seem like a fine mesh to me...
cfx |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
