May 20, 2016, 14:54 |
Coefficient loop iteration
Ali
Rep Power: 10 |
In CFX solver control , there are two options namely "Max. Coeff. Loops" and "Min. Coeff. Loops". What is meant by COEFFICIENT LOOPS here ?
May 20, 2016, 15:31 |
Ali
Rep Power: 10 |
thank you, but what do u mean by "outer loops for your simulation"
May 20, 2016, 15:32 |
Ali
Rep Power: 10 |
May 21, 2016, 07:10 |
Rep Power: 144 |
In a transient simulation you typically do 3-5 iterations per time step. These iterations are called coefficient loops as the equations are linearised for each iteration, so the non-linear part of the Navier Stokes equation is introduced by updating the linear coefficients.
May 21, 2016, 10:59 |
#6 | |
Ali
Rep Power: 10 |
May 22, 2016, 07:25 |
Rep Power: 144 |
The convection term in the Navier Stokes equations (https://en.wikipedia.org/wiki/Navier...okes_equations) is non linear as it has the velocity multiplied by the gradient of velocity. You can't solve this with a linear equation solver. So you linearise it by assuming the non-linear component is constant thereby making the equations linear and solveable by linear solvers. But to account for the non-linearity you then re-calculate the constant you use to model the non-linear component and repeat the process.
cfx solver control, coefficient loop |
GPU - GeForce GTX Titan Black? | frode86 | Hardware | 11 | August 8, 2016 23:36 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 11:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Creating, loop or iteration using expression edito | Jan | CFX | 3 | July 28, 2003 12:01 |
Heat exchanger problem | chiseung | FLUENT | 16 | October 20, 2001 05:36 |
