Transient Analysis Of axial compressor
Old   May 20, 2016, 02:51
Default Transient Analysis Of axial compressor
Rohit S Iyer
rohit_turbo is on a distinguished road
Dear all,
I have presently done a steady state analysis for a single stage axial flow compressor stage and the results are staisfactory.
But, I was keen enough to do a transient analysis in CFX-pre and to my demise everytime I run the CFX solver manager the errors that are being shown are :
COEFFICIENT LOOP ITERATION = 2 CPU SECONDS = 3.833E+02
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory F:/Rohit/Trial |
| Transient/Transient_104Kpa_pending_tasks/dp0_CFX_Solution/96Kpa_90 |
| speed_VG 3mm_002: |
| 0_full.trn |
| The following user files have been saved in the directory |
| F:/Rohit/Trial |
| speed_VG 3mm_002: |
| mon |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
I am a newbie in transient and I have just tried my hands on transient analysis, so pls. If anybody could help with troubleshooting this error I shall be really glad.
Thanks
-Rohit
rohit_turbo is offline   Reply With Quote
Old   May 20, 2016, 03:00
Maxim
-Maxim- is on a distinguished road
Have you read the FAQ about this error and worked your way through the steps?
http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
You should post your CCL and/or your complete OUT-file and maybe some screenshots of your mesh.
-Maxim- is offline   Reply With Quote
Old   May 20, 2016, 03:21
Rohit S Iyer
Dear Maxim,
As I had already mentioned, steady state runs fine with the boundary conditions that I am using, but when it comes to transient analysis it gives the errors. I have attached the image files here.
If you would still require the CCL and the mesh file I shall upload that also.
Thanks
-Rohit
Old   May 20, 2016, 03:30
Maxim
Rohit, please read through that FAQ carefully. If your simulation runs with a certain mesh quality in steady-state, it doesn't automatically mean, that it will run in transient.
Also your time step settings are important. 0.1 minute seems way too high to me.
Some simulations require small time steps to start, but once going the time step can be increased.
And yes, please upload your CCL and/or OUT file and upload screenshots (detailed view) of your MESH.
Your max. coefficient loops are too high. The goal is to have them around 5-10.
I would suggest you do some transient tutorials and use that knowledge to set up your calculation
Old   May 20, 2016, 03:39
Rohit S Iyer
Dear Maxim,
Here are the files.
Thanks
-Rohit
transient.zip
Axial compressor calculation steps? olegmang CFX 38 March 1, 2018 12:14
Turbocharger Compressor Wheel CFD Analysis aymen_a22 ANSYS 1 April 20, 2013 11:39
Axial Compressor experts needed.... arunraj CFX 5 August 17, 2011 20:21
Transient axial rotor/stator convergence issue? Nicola Viscanti CFX 3 March 17, 2010 05:15
Fluent Analysis Of Axial Compressor Puneet Jindal FLUENT 0 June 25, 2009 18:33
