May 19, 2016, 06:53 |
overwrite a variable in CFX pre
Rep Power: 13 |
I would appreciate if you could inform me, is it possible to overwrite a default variable in CFX pre (critical radius in condensation calculations). I want to change this equation some how. |
May 19, 2016, 07:30 |
Rep Power: 144 |
Look at the options in CFX-Pre and see if it is a adjustable parameter. You might also look at the CCL as well as the CCL has more options available than CFX-Pre, so it might be there as well.
May 19, 2016, 09:04 |
Rep Power: 13 |
Thanks for you answer, I found these information in VARIABLES file:
VARIABLE: rcrit Option = Definition MMS Name = RCRIT Long Name = Critical Radius Tensor Type = SCALAR Quantity = Length Status = D User Level = 2 Output to Jobfile = Yes Output to Postprocessor = Yes General Availability = RESULTS, MONITOR, CEL, TRANSIENT STATISTICS Physical Availability = THERMAL, MULTIPHASE Variable Scope = PHASE Variable Class = HEAT Field Variable = True END do you have a suggestion how I can change the equation? I forgot that what does (User Level = 2) means... |
May 19, 2016, 20:35 |
Rep Power: 144 |
As I said, if it is adjustable it will be available in CFX-Pre or CCL. So look there. Just because it is in the RULES file does not mean you can do anything with it.
July 20, 2023, 05:22 |
#5 | |
Chen Junbin
Looking forward to your response. Thank you very much. |
Accessing cell values (CFX Pre and CFX Post) | brahmarishiraj | CFX | 14 | June 24, 2014 20:12 |
Extracting a Geometry from CFX Pre | eh14410 | ANSYS | 0 | June 10, 2014 11:17 |
CFX 11.0 "Vector Variable Normal” Does not Rotate with Domain? User Surface Moving | jrl4444 | CFX | 4 | November 14, 2013 18:46 |
Under Relaxation Factors in CFX Pre | akj | Main CFD Forum | 0 | December 15, 2011 02:50 |
CFX Pre - TGrid | Vivek Vasudevan | CFX | 2 | March 20, 2007 07:31 |
