May 16, 2016, 10:58 |
How to increase mass flow rate in far field
Deepak
Rep Power: 10 |
Hi, does any one know how to increase mass flow rate in far field. I am simulating jet exhaust flow field, but flow rate from far field is not enough. This results very long jet.
May 17, 2016, 01:34 |
Rep Power: 144 |
Please post an image of what you are modelling and what you see as the problem.
May 19, 2016, 02:47 |
Deepak
Rep Power: 10 |
Thank you
Here is link to details of the problem. http://www.cfd-online.com/Forums/cfx...ow-noozle.html |
May 19, 2016, 07:28 |
Rep Power: 144 |
You probably have a velocity boundary condition defined on the far field boundaries. So don't you just make it a higher velocity? Isn't that obvious? Or have I missed something?
May 22, 2016, 03:42 |
Deepak
Rep Power: 10 |
In cfx we can only give pressure and temperature for far field boundary condition.
May 22, 2016, 07:26 |
Rep Power: 144 |
Why not use a velocity boundary condition? If you know the velocity then doesn't this make sense?
May 22, 2016, 08:43 |
Deepak
Rep Power: 10 |
Velocity in far field disrupts main hot core stream. It creates pressure on hot core stream.
Is it possible to make hot stream to draw more free air from far field? |
May 22, 2016, 22:44 |
Rep Power: 144 |
The usual way to model an object in a far field is to use a velocity inlet on the upstream side and the pressure boundary on the outlet side. That allows you to directly specify the free stream velocity on the inlet boundary and allows wakes, exhaust and other things created by the device to simply exit through the outlet.
Would this help? If not you better explain what you are trying to do and why the normal approach does not work. |
cfx |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
DPM total mass flow rate | yow | FLUENT | 0 | July 17, 2015 13:01 |
mass flow rate... | sanjar | OpenFOAM Running, Solving & CFD | 1 | December 2, 2013 01:09 |
