simulation of centrifugal pump with semi open impeller |
May 11, 2016, 14:10 |
junwee
Rep Power: 10 |
I'm new to this software and recently i'm carry out a simulation of semi open impeller by using CFX. Impeller, input/output piping and volute are drawn by using solidworks and I've imported IGES file into geometry and mesh it.
I had facing a problem defining the volute,hence I temporary exclude the impeller in this question.Hence, I draw a simple mechanism. Question: The volute is extruded by a feature so called "thin extrude" in solidworks. It has 1mm thickness and this result another body in ansys. I couldn't run in "solution" in ansys and that is the error i get. Pretty sure the 'thin extrude' features has bring me some issues as I had tried the same thing without 'thin extrude'(totally solid) i am able to simulate a simple flow simulation. Last edited by kumar93; May 26, 2016 at 15:11. |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
Centrifugal pump simulation | Aibolat | FloEFD, FloWorks & FloTHERM | 0 | September 24, 2014 02:37 |
Centrifugal Pump Impeller design | invincible328 | Main CFD Forum | 27 | September 21, 2014 11:59 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
