May 2, 2016, 11:57 |
#21 |
Rep Power: 17 |
Still I do not see what you see. Looking at your 1st pic, generally I see many dots near the suction surface of the pump impeller, and relatively higher velocity vectors near the pressure side. From the inlet your operating point undergoes a large negative incidence.
May 2, 2016, 13:07 |
#22 |
ngoc tran bao
Rep Power: 10 |
Turbo, I think this picture will help, feel free to correct it if I'm wrong. |
May 2, 2016, 13:20 |
#23 | |
Rep Power: 17 |
Have a look at leading-edge area. I see large flow separations on the suction side due to very high incidence from your part-load operation flow. No issues I see from your cfd. |
May 2, 2016, 22:52 |
#24 |
ngoc tran bao
Rep Power: 10 |
I have read some papers and I found that in their research the flow separation which occurs at suction side likes this below pic . On pressure side, the flow is attached on the blade and follows the curvature well (different from my pic) and that is the right behavior the flow should be.
May 3, 2016, 22:16 |
#25 |
Rep Power: 144 |
If your simulation is running at off-design conditions then all sorts of weird stuff happens.
If your simulation is not converged you can also get weird stuff happening. And finally, if your simulation is actually transient and you just look at a single frame of a transient simulation things can look weird as well. You might need to do a time average to get a good mean flow field. |
[Help!] impeller torque calculation: pressure and viscous moments | ghost82 | Main CFD Forum | 1 | March 27, 2014 03:37 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 09:42 |
Strange Velocity in impeller of MRFSimpleFOAM | waynezw0618 | OpenFOAM Running, Solving & CFD | 50 | December 21, 2009 10:45 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 07:10 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
