Merge Stator/Rotor in CFX
Old   April 21, 2016, 08:01
Default Merge Stator/Rotor in CFX
Florian
Dynamic94 is on a distinguished road
i want to simulate one stage of Stator/Rotor. I create the geometry in BladeGen, create for each geometry the mesh seperatly in turbogrid and now i want to add both in one passage in cfx.
My problem is when i link both with cfx that both meshes start at the same position and dont building a stator/rotor stage. I can't transform them.
In the tutorial Stator/rotor the two meshes start at the perfect position after loading the meshes.
My question is how can i add both geometries/meshes to one stage? Must i take a special setting before i link the turbogrid cells to cfx ?
Thanks for your support
Dynamic94 is offline   Reply With Quote
Old   April 21, 2016, 10:53
turbo is on a distinguished road
In CFX-pre, loading each mesh separately in the correct rotating frame, you will see both domains in a good position. If both start at the same position, your geometry in BladeGen might have wrong axial coordinates.
turbo is offline   Reply With Quote
Old   April 22, 2016, 03:20
Florian
Thank you very much Turbo!
I set the wrong axial coordinates. Silly mistake
Thanks for your support!
cfx, rotor, stage, stator
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 03:43
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
PhD using CFX Rui CFX 9 May 28, 2007 06:59
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 05:47
