Constant Power Fan Model using General Momentum Source
Old   April 14, 2016, 14:09
Default Constant Power Fan Model using General Momentum Source
Daniel Norton
Dano62 is on a distinguished road
Hello all,
I'm trying to create a constant power fan model by using a general momentum source, and I'm finding that what I've created is not responding properly.
My current model defines dP/dx for the general momentum source as the power of the fan divided by the volume of the fan divided by the volumetric average velocity. The equation i used is as follows:
-abs(287492[kg m^-1 s^-3]/volumeAve(v)@Fan Blades)
The -abs was used to prevent backflow, and the fan direction is in the - y direction. 287492 is the power of the fan divided by its volume. The region 'Fan Blades is the general momentum source model.
Unfortunately, this model is not reacting properly to ground effects. For example, when this fan model is placed at 0.75 fan diameters above the ground, I would expect that the fan should generate about 12.5% additional lift when compared to a fan operating far away from the ground. I'm not detecting any measurable change in lift, and the fan's velocity does not change either.
If I back-calculate the power of the fan from my results using CFD Post's force_y()@FanBlades * volumetricAve(velocity_v)@FanBlades then the total power is within about 1% of my expected total power. However, I instead calculate the force as the difference in pressure between the top and bottom of the fan then there is a substantial difference between the calculated total power and the expected total power. The diameter of the fan is almost constant.
If anybody has any guidance on how to properly model the force generation for a constant power fan then it would be very much appreciated!
Dano62 is offline   Reply With Quote
constant power fan, general momentum source, ground effects
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
Fan heater model: what turbulence source to use? andy20 Main CFD Forum 0 March 2, 2008 13:46
Modeling a fan with a momentum source Pascale Fonteijn CFX 2 November 21, 2002 17:33
