Problem in Axial turbine stage NonEquilibrium Calculation |
April 13, 2016, 01:38 |
Bharath kumar
Rep Power: 17 |
Hi to all
I am doing simulation for Axial turbine (Steam turbine) Last Stage Blade Non Equilibrium calculation using IAPWS table. 1)For Droplet Condensation, I used MUSIG approach for different size particle diameters (1µ to 20 µ). While doing post processing, I found that steam(liquid) temperature (Tl) is more than steam (Vapor) temperature (Tv). Tl > Tv 2) However when using small droplets model Steam (liquid) temperature is less than Steam (Vapor) temperature. Tl < Tv and I think this is right. Why Tl > Tv in MUSIG approach? Could any body help me regarding this issue. Thanks in advance |
April 19, 2016, 01:15 |
Bharath kumar
Rep Power: 17 |
After further study I found the reason for this. At first in both models Tl>Tv.(i.e) steam (liquid) temperature is greater than Steam (gas) temperature. Previously, I noted it wrong. Steam (gas) is in super cooled state (otherwise metastable region) Tl is greater than the Tv. This is possible in meta stable regions and nucleation barrier is stopping steam (gas) to convert into liquid. Thank you all. |
Problem in Torque calculation | Achilleas | CFX | 21 | July 25, 2018 10:14 |
problem in the calculation of pressure drop for an axial turbine | aja1345 | FLUENT | 0 | January 1, 2016 15:07 |
Problem in Torque calculation | Achilleas | ANSYS | 0 | October 1, 2015 09:56 |
Problem with inv_ONERAM6 parallel calculation | burchio_cfd | SU2 | 6 | December 2, 2013 15:16 |
Pressure calculation for internal problem using 3D panel method | Vitek | Main CFD Forum | 1 | November 10, 2013 12:15 |
