Warning due to Pitch Change Option Automatic
Old   April 12, 2016, 11:45
Smile Warning due to Pitch Change Option Automatic
Jimmy
Jimbo3614 is on a distinguished road
Hello everyone, I was hoping you could help me. For my university project, I am currently setting up an analysis of a 13 stage steam turbine using Ansys CFX. I have set up all of the domains and interfaces but seem to get the following warning:
In Analysis 'Flow Analysis 1' - Domain Interface 'Extraction Row 11 to Row 11': Pitch Change option 'Automatic' is not valid if side 1 or 2 of the interface has a 360 degree or greater pitch angle, zero radius, mesh faces normal and parallel to the rotation axis, or mesh faces at the hub curve (low radial or axial position) which are thin in the radial or axial direction.
All other interfaces are fine and I cannot find the issue with the interface between Extraction row 11 and Row 11.
Does anyone have any thoughts? I have heard you can manually set the pitch of the domains, how is this done?
Jimbo3614 is offline   Reply With Quote
Old   April 13, 2016, 01:47
Bharath kumar
bharath is on a distinguished road
I think it is no problem (just a warning) you can continue to run.
bharath is offline   Reply With Quote
Old   April 13, 2016, 05:13
Maxim
-Maxim- is on a distinguished road
you should be fine. It's just a warning and not an error.
In my case I do a full 360 degree simulation and I have to chose 'none' as pitch change. My warning message is: "[...] The interface is placed at a rotor-stator interface and the pitch change option of 'None' has been selected. This option should only be used when the overall extent and shape of each side of the interface perfectly match and the surfaces are aligned with each other. It may therefore be suitable when full 360 degree or exactly equal pitch components are being analyzed."
-Maxim- is offline   Reply With Quote
Old   April 13, 2016, 05:40
Smile
Jimmy
Hi Bharath & Maxim,
Thank you very much for your input, I thought it was just a warning.
All of my other interfaces had no warnings so this just seemed weird.
Thanks again!
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
