April 8, 2016, 11:54 |
Boundary conditions - Mass Flow Rate
Pedro Ferraz
According to the method of Euler equation for turbomachinery, I have designed the rotor geometry (Hub / shroud / blades) which operates according to the characteristic curve of operation.
Now, in CFX, I have set the mass flow as a boundary condition at the fan inlet, and I want the simulation determines the pressure variation for a given flow rate mass and set rotor rotation! So i cannot impose any pressure on the boundary condition at the OUTLET of the fan. What should i choose? It is correct if I choose again the mass flow as a boundary condition at the outlet? I want to determine the characteristic curve. thanks |
April 8, 2016, 12:41 |
Rep Power: 17 |
You will need to read CFX manual for BC settings before asking here.
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Boundary conditions for flow in nozzle | kgevers | FLUENT | 0 | July 26, 2015 13:46 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 05:59 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 11:44 |
