April 6, 2016, 09:55 |
Automatic wall function parameters
Moritz
i've got a question concerning the parameters used in the automatic wall function treatment when using the SST model. I am simulating the case of a temperatur dependent viscosity oil in a 2D-channel with wall heating. As shown in some papers with DNS in this topic, the elevation of the log-layer in the velocity distribution ist highly influenced by the viscosity ratio near the wall due to the heating. I have already simulated my case with a fine mesh and got the same result for the velocity distribution and the wall shear. Now the aim of that study is to get an acceptable result for a coarse mesh by implementing a model change. Therefore I want to modify the parameter C in the log law used for : I could not find anything on this case in the manual or other forum threads until now. Thanks for your help in advance |
April 6, 2016, 20:14 |
#2 | |
Rep Power: 144 |
Quoting Opaque:
From this thread: http://www.cfd-online.com/Forums/cfx...nce-model.html |
April 7, 2016, 11:39 |
Moritz
Thanks for your reply Glenn
I wasn't referring to the eddy viscosity but to the wall friction velocity. Anyway I found a way to modify the wall function for the momentum by activating beta features for physics and implementing a user defined wall function coefficient. |
April 7, 2016, 19:15 |
Rep Power: 144 |
Oops, sorry - looks like I did not read your post close enough. Good to hear you found a way anyway.
By the way, you could probably also do this by defining your wall with a specified wall shear stress. |
automatic wall function, log law, sst |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
BSL Automatic Wall Function - Shifted koordinates | Sali | CFX | 0 | April 26, 2007 06:04 |
SST model Autometic wall function parameters? | David | CFX | 0 | November 24, 2005 05:47 |
