Interpolation of Values to New Mesh
Old   April 6, 2016, 03:54
Default Interpolation of Values to New Mesh
dyson ilia
dyson is on a distinguished road
hello
my problem { Interpolation of Values to New Mesh}
plz help if possible
| Remeshing |
Remesh Object: Remesh 1
Activated by condition: Interrupt Condition 2
Executing remesh command:
"C:\Program Files\ANSYS
Inc\v150\Framework\bin\Win64\runwb2.bat" -B -R
C:\Users\Dyson\Desktop\work\WB_Remesh.wbjn
CFX Solver Results generated before remeshing have been written to:
C:\Users\Dyson\Desktop\work\Fluid Flow CFX_001\150_oldmesh.res
Text output generated during remeshing has been written to:
C:\Users\Dyson\Desktop\work\Fluid Flow CFX_001\150_remesh.out
| Interpolation of Values to New Mesh |
| ANSYS(R) CFX(R) Interpolator 15.0 |
| Version 2013.10.10-08.49-130242 Thu Oct 10 11:12:50 GMTDT 2013 |
| Executable Attributes |
| single-64bit-int32-supfort-optimised-noprof-lcomp |
| (C) 2013 ANSYS, Inc. |
| All rights reserved. Unauthorized use, distribution or duplication |
| is prohibited. This product is subject to U.S. laws governing |
| export and re-export. For full Legal Notice, see documentation. |
| Job Information at Start of Run |
Run mode: serial run
| Host | Mesh | PID | Job Started |
| | Part | | DD/MM/YY | hh:mm:ss |
| SERVER5 | 1 | 6400 | 06/04/16 | 10:49:37 |
| ****** PROBLEM REPORT ****** |
| Subsystem: Input and Output |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| REDHDR: locating dataset failed: what=G/NAMEMAP where=EVERY |
WARNING: CFXSTP, Regression check error.
| An error has occurred in cfx5solve: |
| Error interpolating results onto the new mesh: C:\Program |
| Files\ANSYS Inc\v150\CFX\bin\winnt-amd64\solver-pcmpi.exe exited |
| with return code 1. |
| The following user files have been saved in the directory |
| C:\Users\Dyson\Desktop\work\Fluid Flow CFX_001: |
| cfxpre_engine_error.log, 150_remesh.out, 150_oldmesh.res |
This run of the ANSYS CFX Solver has finished.
Project File: C:/Users/Dyson/Desktop/work/RemeshingFinal.wbpj
Monitor: ReMesh
Value: 1.00000000e+000
Monitor: Mesh Quality
Value: 2.43303657e-001
Monitor: Ventil_Hub
Value: 7.75000143e+000
Monitor: y valve
Value: -1.50000023e-005
Parameter: Mesh Min Size
Expression: 0.5 [mm]
Value: 0.5 [mm]
Parameter: Ventil_Hub
Expression: 4 [mm]
Value: 4 [mm]
Replaced by value: 7.75000143e+000
Batch run of "C:\Users\Dyson\Desktop\work\Fluid Flow CFX_001.dir\meshUpdate.pre" failed due to the following errors:
-- ERROR --
The location of boundary "Valve" is invalid:
Region "Valve Surface" is not recognised.
ERROR in ReadDataBlockHeader: Reading block size
dyson is offline   Reply With Quote
Old   April 7, 2016, 03:31
Lance
Lance is on a distinguished road
First of all, do not send messages privately about things you also post in the forum.
The error message below could indicate that your remeshing failed for some reason. Check the output of the mesher.
-- ERROR --
Lance is offline   Reply With Quote
Old   April 10, 2016, 07:42
Thumbs down !!!!!!!!!!!
dyson ilia
What does that mean !
Old   April 10, 2016, 08:07
What does that mean?
I think Lance has identified the problem for you - either your mesh or its configuration in CFX-Pre. I bet your CFX-Pre file has a boundary called "Valve" which references a boundary face named "Valve Surface", but you changed the mesh file and the new mesh does not have "Valve Surface" in it.
So it is over to you to tell us whether that worked or not, or provide more information.
Old   April 10, 2016, 08:34
Default *
dyson ilia
thanks,
No, i dont changed the new mesh, and my new mesh contain the "Valve Surface" boundary.
Old   April 11, 2016, 04:10
Lance
You're welcome. Did you check the output of the mesher? Any errors?
Old   April 13, 2016, 07:34
dyson ilia
NO error was in mesher output, Dear Lance
Old   April 13, 2016, 08:09
Maxim
-Maxim- is on a distinguished road
as Glenn says:
Originally Posted by ghorrocks View Post
[...] or provide more information.
So: how about posting those .out/.log files? How about providing a screenshot of your setup (showing regions/boundary 'Valve')?
-Maxim- is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
CFX FSI Fatal Error unbanana CFX 0 October 3, 2015 06:57
Discrete Values for Mesh Motion UnderwaterAlex CFX 2 February 21, 2008 19:21
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
