April 6, 2016, 01:18 |
Property changes in the simulation
Charlers
I am modelling a dam-break scenario. The dam consists of two layers. I hope that two layers can fail at different time. The top layer fails after 10 seconds. The second layer fails after 20 seconds. How to setup the property of these two layers? Do I need to set them as fluid and then change their viscosity? Or do I need to set them as solid and then change to water? Thanks a lot.
April 6, 2016, 06:12 |
Rep Power: 144 |
The easiest way to do this is to model it as a wall, then stop the simulation and restart with a new simulation which has the wall removed. Repeat for the second dam break.
This can also be done using conditional flow with interfaces. These methods are far superior to what you suggest. |
April 7, 2016, 01:39 |
#3 | |
Charlers
dynamic viscosity |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
Wind Tunnel Flow Simulation Mass Flow BC Issue | ledelman | SU2 | 4 | August 3, 2014 18:38 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 08:18 |
