CFX Solver stopped with error when requested for backup during solver running
Like Tree16Likes
Old   April 21, 2016, 21:26
Faizan
Mfaizan is on a distinguished road
Hi Glenn,
I totally agree with you but there is something happening beyond my control and I can not change it as it is locked. I share with you as how I developed the mesh.
1. First I developed the nozzle,hpgas and air geom on designmodeler all together.
2. Then I hide 2 items and save as separate nozzle file. separate hpgas and air file.
3. Then I call three different files one by one on icem using ansys workbench and assembled them.
4. Then I created the mesh of all three domains in assembled form using blocking method. I used O-grid as well.
5. Then I separated the mesh files separately as nozzle, hpgas and air.
6. Then I exported each file into ansys cfx format separately as nozzle, hpgas and air.
7. Then I called these three files into ansys workbench one by one and throw them into cfx-setup on workbench.
8. I got three different domains in cfx-pre.
9. Then I connect the overlapping face of three domains using interface option called GGI.
10. then I started the solver and got this mesh statistics.
Now the mesh quality (Ortho, exp factor and aspect ratio) I generated in ICEM is different from what I got in CFX- Solver. Since solver running, I can not change the mesh at all. It's an automatic connection of nodes and mesh among three domains in CFX Solver which is beyond my control.
I hope I explained the things and you can understand now as why I think the mesh first generated is OK for supersonic flow at high conditions.
Now please suggest what should U do smartly to overcome convergence. Moreover is there any option available called dynamic or adaptive mesh in CFX-Pre/Solver which can fix mesh dynamically.
Please suggest. thanks for your guidance.
kind regards,
Faizan
Mfaizan is offline   Reply With Quote
Old   April 21, 2016, 21:48
The FAQ I posted previously describes what you can do in this situation: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Let me explain what I mean by mesh quality more completely. Your list describes the basic steps of setting up your simulation. I am referring to exactly how you do the meshing step only. The quality of the mesh you define here is critical.
Please post an image of your mesh. Pay particular attention to the mesh around the shock waves. If we see your mesh I suspect we will be able to be more specific.
Old   April 21, 2016, 21:54
Faizan
Hi Glenn,
Please suggest which mesh file would you wish to review. ICEM Mesh Images or the CFX-Solver (Finally running) mesh images. I explained you the situation earlier that cfx-solver is changing it automatically. So which one would be important for you to review? I will post images of mesh you are suggesting.
Kind regards,
Faizan
Old   April 21, 2016, 23:00
Images of the mesh is all I want to see. Some cross sections would be good, also some of the external mesh. The area around the shock wave is the critical area so in the area of the shock please.
Mfaizan likes this.
Old   April 21, 2016, 23:03
Faizan
Hi Glenn,
I am sending the mesh pics of currently running CFD case.
Please have a look and suggest. If you need more images, please suggest.
Look forward to hear from you,
Regards,
Faizan
File Type: jpg Nozzle Exit-Mixing with cylinder surrounding air domain mesh.jpg (201.7 KB, 6 views)
Faizan
one more pic
File Type: jpg Region close to nozzle convergent section.jpg (201.1 KB, 5 views)
Old   April 22, 2016, 00:01
Faizan
x section mesh images
File Type: jpg overall x section away form nozzle exit.jpg (205.1 KB, 2 views)
File Type: jpg x section away from nozzle exit in surrounding domain.jpg (203.3 KB, 2 views)
Old   April 22, 2016, 00:02
Faizan
one more x sec pic
Old   April 22, 2016, 00:30
I am not surprised you have a problem with convergence with that mesh. It has massive jumps in mesh size in several locations. Below is some marked up comments.
Old   April 22, 2016, 00:32
Another point:
Can you model this as 2D axisymmetric? That will make it run much faster.
Are you modelling the solid which forms the nozzle as well? If so, why? Do you want to know the temperature profile of the nozzle?
Mfaizan likes this.
Old   April 22, 2016, 01:36
Faizan
Hi Glenn,
Thanks a lot for identifying the mesh related issues.
I developed big mesh prior to this. I am posting the cross section of big mesh at throat area. Please suggest if it is OK.
I am performing a 3D analysis so 2D axis symmetric study is out of question.
Yes I need to study the temperature variation within the nozzle wall during the flow. As I mentioned it is a 3D study.
I did refinement at nozzle exit because at this thin plane high velocity nitrogen is mixing with atmospheric air. It's a 3D multicomponent model study. As I told you I import three mesh files in CFX-Pre. And this condition at interface is beyond my control. It's auto.
If I send you the ICEM nodes seeding of my three different domains nozzle,hpgas and air. Would you suggest me the best distribution of nodes. I used bigeometric for nodes distribution. Can you suggest any better rule to develop mesh which can support supersonic flow convergence.
Regards,
Faizan
Old   April 22, 2016, 01:38
Don't do mesh refinement when you are still getting the basic model working. Start with a coarse mesh with even element sizes. Once that is working then you start refining the mesh.
Mfaizan likes this.
Old   April 22, 2016, 01:44
Faizan
No this big mesh was also a failure. Not working and always giving error code 1.
Old   April 22, 2016, 01:59
You need your mesh fine enough to capture the basic physics of what is going on. If it is too coarse then it will fail with strange errors. So you need to be finer than that. But the mesh you showed was too fine with far too much mesh grading.
Mfaizan likes this.
Old   April 22, 2016, 02:27
Faizan
Hi Glenn,
Thanks. Can you guide me on ICEM. Should I send you the pic of hpgas mesh first showing no. of nodes for grids.
Pl. suggest. I would truly appreciate your support at this crunch point.
Regards,
Faizan
Old   April 22, 2016, 02:37
Try the Geometry and Meshing forum for advice on ICEM.
But to start you off I would remove the mesh grading you currently have, or at least reduce it. Your aim is to make sure the size of any 2 adjacent elements is the same with 20%, or 10% if you can.
Mfaizan likes this.
Old   April 28, 2016, 22:05
Faizan
Hi Glenn,
As you suggested in your last response. I am trying to read between the lines as stated "size of any 2 adjacent elements is the same with 20%, or 10% " means the the ratio should be 1.2 or 0.2. As I stated earlier that i used bigeometric option and node distribution growth was 1.2.
Please suggest if I am thinking on right path or wrong path under your instructions.
thnaks
regards
Faizan
Old   May 8, 2016, 13:57
Default errro about ansys
  #38
thŕnh
quangthanh94 is on a distinguished road
cacn you help me with this wrong? thank you
quangthanh94 is offline   Reply With Quote
Old   May 8, 2016, 21:02
Faizan
The solution component is unable to find the file from CFX-Pre cell. Right click on solution cell and click on the option suggesting read file from CFX-Pre cell. The solution would be updated. Thanks.
Old   May 12, 2016, 22:19
Faizan
Hi Glenn,
I would like to use this platform to thank you that my 3D supersonic model is running successfully on coarse mesh. I also performed grid independency test by further reducing nodes to 50% with the existing one. I observed the velocity at nozzle exit and the difference in velocity is 0.13%. It means the coarser mesh has no significant effect on the outcome or variables of 3D model.
Thanks for your timely support. I appreciate. I also thank other people who contributed to resolve the matter.
Cheers,
Faizan
-Maxim- likes this.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
