Modeling Jet Fans in Parking Ventialtion
Old   April 4, 2016, 04:42
Default Modeling Jet Fans in Parking Ventialtion
Tarek Jaafar
tj343 is on a distinguished road
Hi , I'm new to CFD. I'm modeling a parking ventilation system in ansys CFX. I'm having some trouble modeling the jet fans . I went as follows. I created a fresh air inlet (Opening BC), an exhuast outlet (outlet BC) and in the middle I distributed jet fans .The jet fans are modeled as sub domains with momentum sources(momentum calculated from the thrust). In addition, I simulated a fire through flow inlet BC at a surface with and additional variable(smoke). I ran a transient analysis. The problem is the results seem unreal.
Generally, how does my methodology look. Am I on the right track. Any tips or ideas about why my results seem unreal.
Thank You
tj343 is offline   Reply With Quote
Old   April 4, 2016, 08:13
Your methodology sounds OK from what you describe.
This is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
LES for jet breakup modeling smog OpenFOAM Running, Solving & CFD 9 December 22, 2015 01:41
side jet modeling for a missile: 1st order or 2nd order scheme AmirBaqa1987 ANSYS 1 March 19, 2014 05:39
[snappyHexMesh] inclined jet modeling simonsg OpenFOAM Meshing & Mesh Conversion 0 March 17, 2014 02:22
Two round jet modeling shg74 FLUENT 0 February 2, 2010 11:47
Modeling a diphasic jet francis Main CFD Forum 0 May 23, 2005 09:32
