torque function
Old   March 31, 2016, 14:54
Default torque function
Pedro Ferraz
Joćo Soares is on a distinguished road
Hi
Im trying to calculate the Input Power (radial impeller) = torque x angular velocity
I read that torque is determined by
M = ||SUM {Fi x Ri}||
The force vector is calculated as a sum of vectors Fni and Fti
I defined a new coordinate system at the center of rotation, and in CFD - POST - FUNCTION - TORQUE, is it applied on the blades and impeller side walls(Hub/shroud)?
I have searching for this in the helps and tutorial documentation, but having no luck finding a solution. I would like to know if someone can explain to me how can i find the torque.
Thanks
Joćo Soares is offline   Reply With Quote
Old   March 31, 2016, 16:00
turbo is on a distinguished road
If you ask for impeller CFD, what you try to get is called "aerodynamic power", not the real input power in testing (because you handle with flowpath only). Forget about torque for that. Aero power (kW) = mass flow (kg/s) * Delta Enthalpy (kJ/kg).
turbo is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
