March 30, 2016, 11:38 |
Rotating-Stationary mesh interface in CFX
Jack
Rep Power: 11 |
I create a mesh of a single passage for a compressor blade using Turbogrid, then ship the mesh to CFX for simulations. The mesh consists of a single domain called Rotor. It consists of an inlet block, main passage, and an outlet block. I am using the Turbo Mode Wizard to set up the boundary conditions. The simulation is run with a "Rotating" Component type to simulate the rotation of the rotor. I don't have a stator down stream of the rotor, however I want to analyse the flow in the non rotating, stationary frame of reference at the outlet of the rotor as this is the flow that would impact the stator. Is there anyway of easily changing the interface between the main passage and the outlet block of my mesh so that the outlet block is not rotating?
April 1, 2016, 06:54 |
Maxim
Rep Power: 13 |
I'm not completely sure if I understand your question right. But you can evaluate variables like velocity etc. in a rotating domain in 'Stn Frame' (stationary frame).
Additionally, you can add a monitor point and select 'Stationary' as 'Frame Type'. I haven't used that yet, but I just added a monitor point for my next calculation - just to see what happens Also a picture of your situation always helps us to understand your problem quickly. |
April 1, 2016, 09:59 |
Rep Power: 17 |
The rotor outlet block in Turbogrid is needed only for mesh generation technique that we do not want really for CFD. What I use is to set the hub in the block as a counter-rotating wall so that it will be stationary. Shroud in the block will be included in your shroud stationary wall definition. Try to minimize the outlet block distance in Turbogrid, but still we need some. Good question.
cfx |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
How to do proper set up for interface, if stationary & rotating domain is there | rgunjegaonkar@gmail.com | ANSYS | 1 | April 14, 2016 07:46 |
horizontal axis wind turbine- Issue in interface b/w stationary and rotating domain. | srijithbbk | CFX | 5 | February 22, 2016 05:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
